First post, by eddman
I'm trying to run the original retail Medieval: Total War, however it crashes after the intro video. Patch 1.1 is applied.
Compatibility modes and dgvoodoo2 didn't help either. I tried a ddraw.dll from PCgamingwiki, made for this game, but no change.
Anyone managed to make it work on modern windows?
EDIT:
It does launch with DXWnd, however I need to use dgvoodoo for API tracing; don't know how to combine them. Putting dgvoodoo's files in the game directory causes DXWnd to fail with a Direct3D error message.
Reply 1 of 4, by BEEN_Nath_58
Well you can use DxWnd for API tracing too (what are you doing anyways?) Otherwise you may need to contact both devs simultaneously for a fix.
In some cases, using DxWnd Renderer - None and putting dgVoodoo2 should fix the problem but it seems unlikely here
Reply 3 of 4, by BEEN_Nath_58
eddman wrote on 2023-09-27, 19:21:
How can I trace with DXWnd?
Setting DxWnd's renderer to none made it work with dgvoodoo, but then the same crash-after-intro happens.
file.php?mode=view&id=174744
    22.25 KiB
