Jetway j-403 com ports
First post, by Jester
I have this 486 system ive been putting together. It can be finicky cuz it’s old and occasionally I must reseat the controller card or the 4x4mb 30pin ram or I’ll get the long beep at power on.
https://theretroweb.com/motherboards/s/jetway … -v2.0#downloads
The attachment 2D11AD1A-73DD-4DE0-86D3-872E0AF142B0.jpeg is no longer available
The last piece of the puzzle is getting a serial mouse to work. I have some Logitech mouseman mice that come with the green ps2 to serial adapter. The frustrating thing is that I never got mouse.exe from Logitech 7.x or 8.x installs to recognize the mouse.
Syschk.exe shows valid com ports but sometimes the com port shows a ? question mark in place of an assigned irq . I’ve tried several controller cards, one goldstar Isa and another eide vlb which gives same results. Is it possible that the motherboard is the problem? The jetway board has an ami bios and it’s the one that is supposed to have mouse support for changing the options. I don’t like it and wish I could hot flash it to something else. I don’t see any mention of serial or com port options but I guess that’s because that isn’t on board. There’s only a “mouse support enabled” option under advanced.
Thanks for your suggestions.
The attachment F7D8E0E8-E7A2-4923-B41C-D321C3C94778.jpeg is no longer available
The attachment EB2804CF-A616-4DAD-824B-DEBE31A68E68.jpeg is no longer available
The attachment 51061AA6-BBC0-47C3-8B80-E221FAD0B394.jpeg is no longer available
Reply 1 of 18, by Jester
Is the elusive irq with ? question mark a conflict or just a com port without assigned irq (needs jumpers)
The attachment 1D4575E5-EF02-4266-AD42-E138CCE6F728.jpeg is no longer available
Reply 2 of 18, by jakethompson1
Did that port on the ribbon cable come along with the board or separately?
There are two pinouts for those serial headers, basically 1-2-3-4-5-6-7-8-9-10 vs. 1-3-5-7-9-2-4-6-8-10
Reply 3 of 18, by Jester
jakethompson1 wrote on 2023-09-27, 02:10:
Not sure, since I have a lot of old stock. I have tried some I/o controller cards where the serial port is on the same bracket. I’ll try that controller tonight and jumper it so the irq shows properly in syschk.exe
Reply 5 of 18, by Jester
Tried ctmouse but still did not detect. Not sure what I’m doing wrong. I have two ps2/serial compatible mice attached. One is Microsoft Intellimouse trackball with 68666 labelled adapter and the other is a Logitech three button mouseman also with included conversion adapter.
Reply 6 of 18, by rasz_pl
on the picture you are still connected to ribbon cables, as mentioned earlier those might be wired differently from what the card expects, safest to verify with multimeter/oscilloscope. Easiest to control are DTR and RTS lines https://en.wikibooks.org/wiki/Serial_Programm … ontrol_Register
run debug.exe
type 'o 3fc 0'
measure voltage on every pin of COM1 header directly on the card, write it down
type 'o 3fc 1'
measure voltage on every pin of COM1 header again looking for one pin that changed, write it down as DTR. It should be either pin 4 or pin 7.
now plug your ribbon cable, poke a needle into DB9 hole number 4 https://www.usconverters.com/index.php?main_p … id=61&chapter=0 and check if there is voltage there
type 'o 3fc 0'
check if its gone
Reply 7 of 18, by Jester
Just gives errors
The attachment CFD6A1F2-2131-4FC4-AACC-FDC9AD77A2BD.jpeg is no longer available
Reply 8 of 18, by rasz_pl
blaming vogons fonts, o0O. o letter, 0 zero
code tag helps, so its my fault after all 😀
type 'o 3fc 0'
type 'o 3fc 1'
Reply 9 of 18, by Jester
rasz_pl wrote on 2023-09-28, 15:21:
blaming vogons fonts, o0O. o letter, 0 zero code tag helps, so its my fault after all :) […]
type 'o 3fc 0'
type 'o 3fc 1'
Doesn’t work? Maybe show a screenshot so I don’t interpret the word “type” literally.
The attachment 166CC200-CCC5-4E6C-A961-64FDB8ACB587.jpeg is no longer available
Reply 10 of 18, by Jester
It looks like both my ribbon cables are “straight through”, pin assignments are the same on the card header as on the 9pin ribbon
The attachment BB7A706E-3488-4D72-891A-BFD31429230C.jpeg is no longer available
Reply 11 of 18, by jesolo
Jester wrote on 2023-09-27, 01:46:
I have this 486 system ive been putting together. It can be finicky cuz it’s old and occasionally I must reseat the controller c […]
F7D8E0E8-E7A2-4923-B41C-D321C3C94778.jpegEB2804CF-A616-4DAD-824B-DEBE31A68E68.jpeg51061AA6-BBC0-47C3-8B80-E221FAD0B394.jpeg
Small favour to ask. Would you mind dumping the BIOS ROM image?
You can do this with a DOS utility called Navrátil System Information (NSSI). Before you do, just enter the CMOS setup and temporarily disable BIOS Shadowing (System ROM shadow) under the Advanced CMOS Setup.
Reply 12 of 18, by CharlieFoxtrot
Jester wrote on 2023-09-28, 17:59:
Your brackets/ribbon cables are wrong for the card, you need a crossed connection.
If you connect your bracket to card header, I bet you don’t get ground on the pin 5 of the com port, this is the easiest way to be sure. You need to resolder the wires in the com port side so that they match with the pinout on the card.
Not long ago I needed to do this with my Zida 4DPS onboard COM port. I have a bunch of these COM port brackets, but none were crossed type.
Reply 13 of 18, by rasz_pl
Jester wrote on 2023-09-28, 17:57:
you said it, yet you didnt test the last possible and most obvious option? :] If we are at a soccer game and I say shout 'GOAL' will you be shouting shout apostrophe GOAL apostrophe? 😮 😀
o 3fc 0
o 3fc 1
this should be flipping voltage on DTR pin
Afaik straight 1:1 are the never type. AT/EVEREX https://pinoutguide.com/Motherboard/rs232_hea … er_pinout.shtml while yours might be DTK/INTEL
You can start with pin 7 on your card while alternating those two commands.
ps: you dont have to type whole o 3fc over and over, keyboard right cursor retypes last command
CharlieFoxtrot wrote on 2023-09-28, 19:07:
doh, so simple and doesnt require any software incantations! Yes do this instead.
Reply 14 of 18, by Jester
Okay right. What is 3fc? Shouldn’t I use 3f8/2f8 to designate the com port? Or is this just the hex for flipping the dts ?
Well the 25pin is built-in to the card so if I could dig up a db25 to db9 converter that would work for the time being. Hella ugly though.
Also found these two Data Technology VLB cards with what looks like the original ribbon cable and db9. Just need to get the jumpers right for them because they show no comports on boot.
The attachment 86F7DBC0-9C54-4352-81A7-AF9FDD257F51.jpeg is no longer available
Reply 15 of 18, by Jester
Sure will give it a try. Is it for archives / debug ?
Reply 16 of 18, by rasz_pl
Jester wrote on 2023-09-28, 19:46:
yes, this register lets you directly set DTR pin voltage https://en.wikibooks.org/wiki/Serial_Programm … ontrol_Register
zUoPaZ6_d.webp?maxwidth=760&fidelity=grand
if one is long enough you could try swapping it into your original card
Reply 17 of 18, by Jester
Just tried that and no good. I believe my two acer chipset isa controller cards need the crossed pin ribbon cable, while all my vlb controller cards are straight through. Every card I try has an issue. The vlb cards I can’t seem to get 3f8 /2f8 com ports enabled using the jumpers on post , while the isa cards I can get com ports but need specific ribbon cable. Some of them won’t post at all.
I might go this path instead and print this isa ps/2 card.
The attachment 18195AC3-4194-4B1D-9CAB-899421B05E49.png is no longer available
The attachment E626661E-9E35-4C4D-957A-8B7094D57BD8.png is no longer available
Reply 18 of 18, by Jester
So the data technology vlb controller card worked finally. I was getting those weird missing irq? in syschk.exe and I decided to take the unecesarry cards out (GVC nic-2002bt and a suncom gameport controller) and the interrupts and mouse work fine now. I’ll try and avoid unknown brackets with serial ribbons and just use I/o controllers with onboard 9pin serial port.
The attachment 9B15D0FB-A400-480B-9AC3-6ABE34D71525.jpeg is no longer available
