First post, by Nibitor
Hello,
i ressurected one of this old warriors, being in very bad shape, corrosion etc.
Now, i want to make some upgrades and first thhing that i noticed is that mobo don't have any cache modules installed.
Does anybody know what type of cache modules this machine uses, where to find them...
Thanks 😀
Reply 1 of 3, by tauro
Does it look like this?
1.72 MiB
If so, you need DIP-28 static RAM modules. Each one should be 32K, and you can install either 128k (4) or 256k (8), plus a TAG chip.
You can find them online, look for SRAM DIP-28.
Here's more information about this board:
https://www.elhvb.com/mobokive/eprm/eprm/f347.htm
https://theretroweb.com/motherboards/s/ibm-pc … 71,-pc-350-6581
https://theretroweb.com/motherboard/manual/IB … 50-486.html.pdf
Reply 3 of 3, by tauro
Nibitor wrote on 2023-10-01, 14:16:
Yes, that is the board...thank you my friend!
You're welcome 😀
It's a solid VLB board with a good on-board video card.
Just beware that it only supports 5v CPUs (unless you have the VRM module)!
