First post, by batmreload
batmreload
Offline
Does anyone know where i can find WDM drivers for windows 98se that DONT try to install the soundblaster compatible modules as well? I have a SB16 PnP allready in the system, and, while i can disable the sb compatibility, it seems to be causing some issues.
I still need the WDM driver installed for use with Deamon tools for cd-audio, as this system can't have a cd-rom.
Thanks!
