First post, by Xanxi
Hi.
I think some of you people might have this 20 years old device as part of their MIDI stack.
I have acquired one recently but i can't get past the encDSP Init Err message when powering the device.
I have understood from the internet this is related to the content of the CF card but i have formatted and restored the factory setup of the CF card as per instructions several time with no success.
Only thing working is connecting to the PC in USB mode.
I would like to use this device as MIDI renderer, not as a studio, but it does not seem to do anything upon receiving MIDI data when i connect it to myu patchbay.
Any idea welcome.
Thanks.
Reply 1 of 1, by DevanWolf
Try this:
Download firmware upgrade v2.07 from TASCAM and extract its contents (UTILITY.LDR file and UTILITY folder) to the root of your CF card. You can use the PocketStudio 5 as a USB CF reader by powering on while holding ENTER.
Hold REW and RECORD while powering on, then press ENTER thrice to begin the firmware update. This will take about 10 minutes.
Now your PocketStudio 5 firmware has been updated and should not get a DSP error anymore. If the error still persists then the board/chip(s) needs repairing.
BTW I am curious about its MIDI synthesizer chip it uses, can you have a look at its internals and confirm that it has a DREAM SAM9793?
