First post, by yukiko
hi all,
Im using the attached
and experiencing a problem on startup, in detail getting this error when the line 67 exists
and getting this error when the line 68 exists
if not line 67+68 exist, run flawless... The need is to create more menu entries... I search over forum & world wide web. I found only, the source code part throwing the error.
Please advise, is any way to avoid this error or a even better way to do a menu?
