First post, by DosFreak
 - l33t++
Saw this at Bink.nu today:
http://www.fs-driver.org/index.html
It provides Windows NT4.0/2000/XP with full access to Linux Ext2 volumes (read access and write access). This may be useful if y […]
It provides Windows NT4.0/2000/XP with full access to Linux Ext2 volumes (read access and write access). This may be useful if you have installed both Windows and Linux as a dual boot environment on your computer.
The "Ext2 Installable File System for Windows" software is freeware.
It installs a pure kernel mode file system driver Ext2fs.sys, which actually extends the Windows NT/2000/XP operating system to include the Ext2 file system. Since it is executed on the same software layer at the Windows NT operating system core like all of the native file system drivers of Windows (for instance NTFS, FASTFAT, or CDFS for Joliet/ISO CD-ROMs), all applications can access directly to Ext2 volumes. Ext2 volumes get drive letters (for instance G:). Files, and directories of an Ext2 volume appear in file dialogs of all applications. There is no need to copy files from or to Ext2 volumes in order to work with them.
FEATURES
Supports Windows NT4.0, Windows 2000 and Windows XP (x86 processors only).
All operations you would expect: Reading and writing files, listing directories, creating, renaming, moving and deleting files or directories, querying and modifying the volume's label.
Now if only Windows could use Ext2 at boot time.....
