AWE32 not working
First post, by Kouwes
I got an AWE32 the other with a ugly dent. Could that cause problems?
Win98 did not detect the card on the first mainboard I tried…Not very promising
Reply 1 of 11, by pentiumspeed
Oscillator crystals has space inside and dent does not affect the function. Unless it was broken.
Inspect rest of the sound card for bad solder joints especially the fine pitch SMD ICs. And anything touching together need to be separated carefully with a razor.
Cheers,
Great Northern aka Canada.
Reply 2 of 11, by Shponglefan
Any physical damage to component is usually not a good sign. It's possible the dented crystal has been damaged internally. I would also inspect for other physical damage because if the card has seen some impacts strong enough to dent a crystal, there could be other damage as well.
Do you have a multimeter to test for things like shorts and continuity?
Sometimes it can be as simple narrowing down to a single faulty component and then replacing that component.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 11, by Joseph_Joestar
If that AWE32 is a non-PNP model, Windows would not detect it by default. You would have to manually install it using the "Add New Hardware" wizard.
I suggest trying Creative's DIAGNOSE.EXE in pure DOS first, to see if it can detect the AWE32. If it can't, then your card might be damaged.
My retro stuff
Reply 5 of 11, by mkarcher
Joseph_Joestar wrote on 2023-10-12, 18:45:
And if the AWE32 is a PNP model and Windows doesn't detect it, the PnP information may be damaged. There are two helpful threads here on VOGONs that contain the required information, tools and data to re-flash the PnP information.
Reply 6 of 11, by maxtherabbit
I've had a bunch of used hardware come to me with dented crystal oscillators over the years, it's never been a problem
Reply 7 of 11, by mattw
I have one PCI sound card, which was hit on the crystal - it was broken, I mean replacing it - make the card working again. so, in this case - nothing is for sure.
Reply 8 of 11, by Kouwes
I swapped the mainboard because I got the feeling the soundcard wasn‘t sitting well in it‘s slot. This board (GA-6BXC with PIII-550) works for sure so that’s one error source I can exclude.
Oh, and I tried the Add new hardware function in Win98 and selected the SB16 / AWE32 but obviously nothing was found.
I‘ll try the AWE with this gigabyte board after work.
Reply 10 of 11, by Kouwes
Well, the card works after all! Seems it just didn’t like that supersocket 7 board.
Win98SE not only recognizes the card, it will also install the drivers.
Reply 11 of 11, by BitWrangler
mattw wrote on 2023-10-12, 23:32:
Yeah, it's a case of, the crystal has plenty of room in there, and damage at about a less than a third of the dimension is unlikely to have contacted it, BUT a shock impact that caused a dent like that, vs maybe a weight/pressure dent, could have shocked the crystal enough to crack it or dislodge it's internal connections.
