First post, by kinetix
hello friends. I have a Compaq DeskPro EN I have recovered and restored (it was even a cockroach nest, eww). as a reference, the same model as this one: Compaq Deskpro EN PD1060 can handle a good AGP card? but with an active cooler and an 866MHz PIII. It has an AIMM module too. but I also have a problem.
PCI graphics cards work on it but not AGP ones.
With some cards the PC immediately issues a video problem (recognizable by the pattern of beeps and blinking the Caps Lock led) . With others it takes a little longer to do so.
Any idea why and what I should do?
Reply 1 of 2, by Repo Man11
What graphics cards have you tried? Dionb's recommendations in the linked thread were good.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 2, by kinetix
Repo Man11 wrote on 2023-10-13, 02:43:
sorry I hadn't seen your comment, earlier.
I was finally able to successfully test some cards. part of the problem seemed to be a dirty slot. thanks
