First post, by AlessandroB
gifted by a frend, theres not any sign…
thanks for your help
Reply 1 of 9, by BitWrangler
Laid out like an ECS K7VMM or K7SEM so smells like ECS, they usually put a label on the side of the bottom slot. Dual RAM type like K7S5A..
Oh look at that it is a K7S5A, https://theretroweb.com/motherboards/s/ecs-k7s5a-v1.1
Reply 4 of 9, by dionb
BitWrangler wrote on 2023-10-13, 12:11:
Yes and no - technically it's the K7S5A, but the ECS version of the board is dark brown/almost black. This beige PCB is the PC Chips M830. Not that that makes any difference other than aesthetics.
Reply 5 of 9, by AlessandroB
So not a great mainboard… everage
Reply 6 of 9, by BitWrangler
dionb wrote on 2023-10-13, 17:07:
Yah, I didn't pick it as K7S5A for sure until I pulled that photo from retroweb where I assumed that if the title was for K7S5A the main photo was actually that, because I thought the one I had was a different color but thought it was my memory playing tricks.
Reply 7 of 9, by waterbeesje
Believe it or not: pc chips has indeed build some really great boards. And they became masters of disguising their own brand die to their reputation. The chipset cooler and no real identity marks also breathe PC Chips to me.
Stuck at 10MHz...
Reply 8 of 9, by BitWrangler
Anyhoo, that design of board... tips... caps bloat in long term use, check for leaking at base. Be gentle with the USB in terms of loads and frequent higher power device swapping, knew a couple of ppl that had the USB fry. Look for a HoneyX BIOS if you want good overclocking options. It is a fairly fast board, but KT266A is better if you get a good one. Should do Thoroughbreds and Bartons and Mobiles with right BIOS.
Reply 9 of 9, by dionb
One more thing: the first BIOS releases for these boards were catastrophically bad, think memory errors and floppy drive corruption - which led to a lot of bricking when people tried to upgrade the BIOS to fix them. If the board POSTs, check the BIOS version. I would expect any surviving K7S5A/M830 boards to have been upgraded long ago (or thrown out if the user wasn't aware issues were BIOS related), but you never know...
If it's 010816, it needs an update urgently. Whatever you do, DON'T try to update from floppy. Put the BIOS image on a hard drive/CF card/whatever and flash from there.
