First post, by Tig77
The manual and hint file for a Windows 95 game I have are actually 16-bit exe's called manual.exe and helphint.exe. They're 16-bit Windows programs which load up a "Common Ground Digital Paper" .dp file contained within the exe. Digital Paper is a proprietary format that was competing for dominance with PDF back in the early 1990's. I am trying to convert the contents of these files to PDF. I looked all over the net to find a converter but I can't find any.
I tried using a PDF printer driver in my Windows 95 virtual machine and using the print function in the manual.exe and helphint.exe files, it works, but the resolution is only 300 dpi, not sure if that's a limitation of the manual.exe or if it's a limitation of the particular printer driver that I'm using, and I've tried a few. 300 dpi PDF output is readable, but I was wondering if anyone with more technical expertise might have another solution to get a higher quality PDF out of these files. It would be great to have easier access to these manuals and hint documents.
The files are attached to this post.
BTW, I'm running on Vista SP2 64-bit.
Thanks for any help you can provide!
    HELPHINT.EXE
    351.72 KiB
    41 downloads
    Hint file "Digital Paper" EXE
    Manual.exe
    360.05 KiB
    40 downloads
    Game manual "Digital Paper" EXE
Reply 1 of 11, by doshea
Does your PDF printer have any DPI settings, if not in the Digital Paper application's print settings, in Control Panel? If not, perhaps you could try installing something like a HP LaserJet driver which is set up to print to file, as I suspect they'd have DPI settings. That would give you a PostScript file you could presumably convert to PDF using something like Ghostscript.
I did a Google search for "digital paper" "common ground" and didn't go through all the results but it looks like at least some Mac version of the creating software might be available. I wouldn't be surprised if it wasn't very useful for converting it to other formats though, but I could be wrong.
Reply 2 of 11, by giantclam
Initially more for poop and laughter, I thought I'd give this a whirl in Debian-12....
...download helptext.exe above, launch it with WINE...
....File->Print-> Print to file ...(this will invoke the builtin wine postscript engine)...give the file a name...ie; helptext.ps....
......launch Okular , File -> Import Postscript as PDF ...select the helptext.ps file created above...
........File -> Save As -> helptext.pdf
Output here attached.
Note: in the 2nd step above, I could've printed via CUPS in 300/600/1200DPI but essentially that would've been just piping the postscript file to the printer driver, and YMMV depending on driver/filter.
    okular_WQTthT.pdf
    336.75 KiB
    45 downloads
Reply 3 of 11, by doshea
That output looks a bit jagged, I guess the text is turned into bitmaps without anti-aliasing at some point? I wonder if that has already been done in the .exe file, or if it's in the process of printing? It's been too long since I've played with this kind of thing, and now I think of it, I think I might have had similar issues myself which I never resolved.
My guess is that my experience with reverse engineering document formats is probably not useful for the Digital Paper format if it's anything like PDF, but I can't help but wonder what it looks like 😁 Has anyone checked with a resource editor (e.g. Borland's Resource Workshop) or maybe even something like 7-Zip whether the document can be easily extracted from the .exe file?
Reply 4 of 11, by Tig77
Thanks doshea and giantclam!
giantclam, the PDF in the quality you created is just what I was looking for. Thanks very much! Would you be able to do the same with manual.exe?
Reply 5 of 11, by Tig77
doshea wrote on 2023-10-15, 00:00:
Has anyone checked ... whether the document can be easily extracted from the .exe file?
Yes, the EXE's have the option to save the document, and it outputs to a .dp file "Digital Paper" format. But I can't find any converters to PDF (or anything else) for it. .dp is a proprietary format, but it would be cool if someone could reverse engineer it to be able to make a converter to PDF for it.
Interestingly, if you select "properties" or something from within the program, it says "file type: Microsoft Word document". So, maybe it could be done, but opening it in Word doesn't yield good results (of course I'm using a more modern version of Word).
Reply 6 of 11, by giantclam
Tig77 wrote on 2023-10-15, 01:50:
Umm... I just had a look ~ manual.exe presents pages in landscape mode on some non-supported paper size (as far as the wine postscript filter goes), so the print to file function ends up in portrait mode (not what we need), and I can't fathom any way to change that in winecfg....
....however, I could grab some images that are in the same sort of quality, and you could import those into a new pdf to make ends meet...will that do? (example below)
Reply 7 of 11, by Tig77
giantclam wrote on 2023-10-15, 02:32:
I guess even when you set landscape mode to print, it still ends up being in portrait? Even when you set the print settings in the manual.exe to landscape?
Thanks, that should be okay. Thanks!
Reply 9 of 11, by Tig77
giantclam wrote on 2023-10-15, 03:11:
To answer your question, no I didn't try printing (direct from manual.exe) as you asked about PDF and not hard-copies =)
Thanks for the other pages. Much appreciated!
Regarding printing direct from manual.exe, there is an option to "print to file" and there you can select landscape mode. I wonder if that would allow the proper layout for a PDF?
Reply 10 of 11, by darry
These are fully text searchable as well and smaller in size .
Detailed workflow (for anyone needing to do something similar):
a) Spin up a Windows XP virtual machine
b) Install a PostScript capable printer on whatever printer port (I chose an HP Laserjet 5 on LPT1). The printer does not need to physically exist as we just need the driver installed . Using one of the bundled XP drivers is fine .
c) run each exe file, select the printer you "installed", set DPI to highest possible, set to landscape (if desired) and check the print to file before "printing".
d) you will be prompted to enter a file name (I chose manuel.ps and helphint.ps respectively). These are in PostScript format
e) Once the files have been created, copy over to modern machine and open each one in GSVIEW (a Ghostscript frontend) and save as PDF .
manual.pdf
96.02 KiB
39 downloads
helphint.pdf
76.92 KiB
38 downloads
Reply 11 of 11, by Tig77
Thanks very much darry! Using a Windows XP virtual machine gives newer and higher DPI printer drivers than Windows 95 for sure. I tried your steps on a Windows 95 virtual machine before I posted here, but was limited to 300 DPI due to the older drivers.
For google search purposes, the manuals in this thread are from GSP's "Pinball Classics" collection which includes "Power Pinball", "Slam Tilt Pinball" and "Arcade Pinball", also known as "Pinball Mania Plus" and "Pinball Collection Vol 1" and "Pinball Collection Vol 2".
