PKUNZIP installation
First post, by rain
hi, cant find any info on google to how to use - install - pkunzip - pkzip on ms-dos 6.22 system.
is there any way unzip files on dos 6.22? thanks
Reply 1 of 4, by Gmlb256
Yes, by typing PKUNZIP and the ZIP file that you want to extract as a parameter. It will extract all the files in the current path.
PKUNZIP example.zip
To extract a ZIP file that has folders properly:
PKUNZIP /D example.zip
The /D command line switch is for recreating the directory structure inside the ZIP file.
Tip: Put the PKUNZIP executable into one of the folders that are in the PATH environment variable so you can run it anywhere.
Reply 2 of 4, by rain
Gmlb256 wrote on 2023-10-15, 16:20:
i put PKUNZIP.EXE on C:\DOS by default PATH on autoexec.bat file and it runs fine.
Reply 3 of 4, by chinny22
yep, I dump it in c:\dos as well
Only thing to add to what gmlb256 said is if you want to extract to a specific folder add that to the end of his command, eg
PKUNZIP /D example.zip c:\games\example
this will unzip everything into the folder c:\games\example but the folder does have to exist first.
Reply 4 of 4, by Jo22
I've got it in c:\tools directory. It's in the "path" variable in autoexec.bat, along with other directories.
path=c:\dos;c:\tools;c:\pctools;c:\windows;c:\pcgeos20;
temp=c:\temp
Other tools in there are pkzip, arc, lharc etc.
Along with things like Norton Commander, drivers, diagnostic programs, benchmarks etc.
The positive thing about c:\dos is that it's hard-coded into DOS kind of.
If you press F5 during boot and skip processing start-up files, the path is still known.
