First post, by theelf
Hi! i came here to ask for advice
Mi P3 motherboard have award bios, what i want is to remove the PCI and pnp hardware list that show on boot
502.95 KiB
Using awardflash tool i save original bios, and edit in MODBIN, I see a option that looks what i want...
625.92 KiB
But after saving new bios and flash, motherboard died, long beep. Lucky me is possible to recover using a floppy
I tried windows tool, but same problem
https://awdbedit.sourceforge.net/
I dont know much about if possible to do remove this info, any idea guys?
One problem i see, is if i compare in a hex editor boot BIOS (original and edited) the difference is TOO MUCH, is not just some bites...
I attach my bios for any ideas, THANKS
original.zip
160.88 KiB
24 downloads
Reply 1 of 5, by theelf
I answer myself! success!!!
The problem was modbin version, was old. Searching i found a newer one
http://old-dos.ru/index.php?page=files&mode=f … do=show&id=7976
Now i can have my P3 like old times... incredible
162.6 KiB
Reply 2 of 5, by Horun
Good work ! There are times I wish the PCI/PnP stuff did not show but would prefer a true bios setting so I can turn it on or off as needed.....
Reply 3 of 5, by Repo Man11
theelf wrote on 2023-10-16, 00:09:
I answer myself! success!!! […]
What version of Modbin did you try initially?
Reply 4 of 5, by theelf
Repo Man11 wrote on 2023-10-16, 01:44:
Hi, i always used 4.50.60 and 4.50.75, and because worked good, never looked for a new version. I never did a bios mod on a new motherboard, always edit 486-Pentium 1 bios, never P3+ ones
My P3 motherboard is a DFI CA61 chipset VIA VT82C693A, and this modbin versions edit the bios OK, but was defective
Finally i found 4.50.82A version work fine, and Award Flash v8.10B to flash.
Award Flash v8.30+ versions corrupt bios when flash, even say flash was OK
Reply 5 of 5, by analog_programmer
Thanks for this info. The same way I killed Gigabyte PIII Tualatin mobo. Now I have to desolder BIOS chip, install PLCC32 socket to motherboard and reflash with programmer.
I found some different versions BIOS editors and flashers here: http://xdel.ru/downloads/bios-mods.com-tools
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
