First post, by Jccwu
Hello There is a given card with a wave synthesizer on board. The card works, FM sounds, OPL music plays. But the on-board synthesizer does not work. Does anyone have such a map, how to achieve the sound of WT synthesis?
Multiwave Innovation Pte Sound Card FCC ID KLZ1105
Sound card's music
Reply 1 of 12, by Babasha
Jccwu wrote on 2023-10-16, 18:40:
This card has internal wavetable and header for external wavetable… so one of the jumpers switch them))) Just try to switch jumpers near main ICs
Need help? Begin with photo and model of your hardware 😉
Reply 2 of 12, by Jccwu
Babasha wrote on 2023-10-16, 18:52:
I did it. By default, the jumper is set to built-in wave synthesis. JP2
Sound card's music
Reply 3 of 12, by Babasha
Jccwu wrote on 2023-10-16, 19:08:
I did it. By default, the jumper is set to built-in wave synthesis. She can be seen from above
JP2 - WAVE EN (wavetable enable, but are you sure its internal wavetable enable or external wavetable enable?).
There 27C256 ROM chip isnt there BIOS extension for card configuration during boot-time?
Reply 4 of 12, by Jccwu
Babasha wrote on 2023-10-16, 19:09:
I tried without a jumper. I don’t know anything about 27C256 ROM
Sound card's music
Reply 5 of 12, by Babasha
Jccwu wrote on 2023-10-16, 19:20:
Its interesting to see all silk signs on sound card:
JP2 - wavetable en
JP3 - nonpnp/pnp (maybe its ROM BIOS extension?)
JP6 - cd en
others???
Reply 6 of 12, by Jccwu
if you install an external daughter card, it also does not play in any jumper option
Sound card's music
Reply 7 of 12, by Jccwu
Babasha wrote on 2023-10-16, 19:27:
Its interesting to see all silk signs on sound card: JP2 - wavetable en JP3 - nonpnp/pnp (maybe its ROM BIOS extension?) JP6 - c […]
JP2 - wavetable en
JP6 - cd en
others???
There are jumpers for SPK/Line out and a jumper for changing the voltage in the power connector.
Sound card's music
Reply 9 of 12, by Jccwu
Babasha wrote on 2023-10-16, 19:36:
According to the first link, the problem is still not solved. This is our colleague on the forum with the same board as me and the same problem.
According to the second link, the problem is solved only by turning up the volume on another card.
Sound card's music
Reply 10 of 12, by Babasha
Jccwu wrote on 2023-10-17, 13:49:
Yeap! Do you try ESSVOL and volume change and NONPNP or PNP modes?
Reply 11 of 12, by Jccwu
Babasha wrote on 2023-10-17, 13:54:
I tried only in pnp mode
It's unlikely that anything will change in nonpnp mode.
essvol enables all synthesizer volume modes by default. I checked.
явно нужен файл включающий mpu на этой карте, но не enpmu
Sound card's music
Reply 12 of 12, by Babasha
Jccwu wrote on 2023-10-18, 15:05:
I tried only in pnp mode It's unlikely that anything will change in nonpnp mode. essvol enables all synthesizer volume modes by […]
PM me i got an idea!
