First post, by kahuna
Hi all,
Just wanted to share a somewhat interesting behaviour I'm seeing running Prince of Persia.
What I'm using is a K6-III+ based machine with a Sound Blaster 64 AWE GOLD that I have connected to an MT32-Pi.
The Prince of Persia version I'm running is 1.3.
The thing is, if I run the game without disabling the cache of the CPU, the MT32 takes care of both music and sound effects.
However, when I disable the CPU cache and lower the CPU speed, I get the music from the MT32, but the sound effects come from the Sound Blaster directly.
The latter is actually the configuration I want, and that's what I have configured using 'setup.exe' 😀
I also tested with SoftMPU loaded, same results.
Not sure if it's just me...
Be free!
Reply 1 of 4, by konc
It seems that the game is "speed sensitive" for what concerns the detection of the Sound Blaster, which is not something uncommon. Many old games have sound issues on faster systems.
Reply 2 of 4, by Gmlb256
It is one of the symptoms of speed-sensitive DOS software around where the computer is too fast for the Sound Blaster detection routine, it isn't just you.
Reply 3 of 4, by TheMLGladiator
Yep, I've also run into a bug where the game will lock up on the intro if it's running in Tandy mode and the cycles are set to high in DOSBox.
Reply 4 of 4, by kahuna
Makes sense. First time I see something like this though, getting the sound effects from the mt32 instead of the Sound Blaster. Interesting 😀
Be free!
