First post, by appiah4
- l33t++
I bought an AT case the other day, got it shipped from a scrapyard and unfortunately due to some poor packaging and an asshole courier it got knocked pretty bad in transit. As a result it as a big break in one corner and a crack in one edge. I want to glue it back, but the glue needs to be:
- Strong bonding for plastic
- Semi flexible
- Gap filling
- Transparent or creamy/white
I've considered using plastic cement that model kit builders use.. With some plastic added into it, they can easily became a gooey colored gap filler, but I'm not sure whether it'd be a great idea for mending broken parts.
What is the general consensus on what to use for these kinds of repairs? Probably some kind of resin epoxy, but which?
