First post, by Navecitas
This laptop has a useless screen, it literally fell to pieces when unfolding it. only a label: PMD-5700
It came with manuals, one of them on the Yamaha YMF715 (OPL3-SA3).
But it didn't have a game port for midi out. drill a hole for 3.5 mm. stereo jack
1.77 MiB
Disassembly and research on yamaha chip:
164.92 KiB
1.02 MiB
1.11 MiB
1.29 MiB
Works good, midi out tested on a Roland RA-50 and SC-D70
Delete or move if this topic don´t go here
Reply 1 of 2, by Tiido
You shouldn't use the AVDD but instead DVDD for the MIDI part, there will be a bit less interference that way. But definitely a way to get going ~
Reply 2 of 2, by Navecitas
Tiido wrote on 2023-10-19, 18:01:
Ok i can see on the datasheet DVDD(digital power supply) = 5v or 3.3v.
i´ll test those pins. if they have 5v. I´ll change the mod
Thanks
