First post, by jasa1063
I am looking for floppy drive cable with an edge connector that is not keyed to go with the pictured adapter. Does anyone know where one could be sourced from?
    293.54 KiB
Reply 2 of 6, by jasa1063
snufkin wrote on 2023-10-20, 14:49:
Would it work just cutting the keying out from a keyed connector? Or add your own connector to an existing cable (searching for '34 way idc card edge connector' seems to give a few options)?
I tried cutting out the keyed part of a standard card edge connector, but I ended up breaking the internal pins each time. That is why I am looking for premade solution.
Reply 3 of 6, by weedeewee
Why not just key the card ? a simple saw would do.
Do not ask Why !
Reply 5 of 6, by weedeewee
google for "34 pin Flatcable PCB edge connector"
Do not ask Why !
Reply 6 of 6, by jasa1063
weedeewee wrote on 2023-10-20, 15:12:
Found this and it should do the trick.
https://www.amazon.com/Connectors-Pro-10-Pack … ics%2C91&sr=1-1
