First post, by EvilCPU
I was sorting through the remains of my collection and found this external drive. I can’t find information about him, I need help in searching or a hint from knowledgeable forum residents. Thx!
Reply 1 of 4, by weedeewee
I'd be hesitant to use the keyboard plug to pull 1A of current. Seems like a recipe to blow a mainboard fuse.
edit: adding all the text so the search engines can have some fun.
SSI Computer P-IDE (HDD & CD-ROM) software driver (Shuttle Manager v2.17d) […]
SSI Computer
Made in Taiwan
Copyright (c) Shuttle Technology LTD
M P H
Mobil Pocket HDD
The World's Smallest Pocket Hard Disk
EPP P-IDE
Diskshuttle CE
Portable Disk System
Model No:SI-500 FCC
FCC ID:
MK6SI10SI5009500
Power Requirements
DC+5v, 1A regulated
by A.C. adapter or
keyboard Power Cable
Warranty void if opened
by unauthorised service
engineer.
Do not ask Why !
Reply 2 of 4, by EvilCPU
weedeewee wrote on 2023-10-20, 19:38:
But people came up with this miracle of engineering, albeit with such a problem as a blowned fuse. I want to understand what it is and why ...
Reply 3 of 4, by weedeewee
It's likely a laptop harddrive in an enclosure that houses an interface which connects to the parallel port and allows for a printer to be connected as well.
Going off on the name it also likely supports an EPP parallel port which should allow for 'fast' transfer speeds if your laptop/computer sports an EPP supporting parallel port.
Do not ask Why !
Reply 4 of 4, by PC Hoarder Patrol
EvilCPU wrote on 2023-10-20, 19:48:
Product - see (foot of page) at https://web.archive.org/web/19970113125555/ht … .com.tw/epp.htm
Driver - see (top one) at https://web.archive.org/web/19970113130511/ht … .tw/drivers.htm
The attachment SSI EPP.jpg is no longer available
