First post, by Iarsin
Hi, is there a possibility to repair or find a replacement part for the broken P8 socket on the Mainboard?
I don't know the exact wording for search such a part on eBay or AliExpress.
I may can resolder one of a currently broken mainboard, but I thought I may try to repair them also.
The PSU seems okay, but before I unplugged P8 and p9 it only rotated the ventilator for a fraction of a moment and then I guess it stopped the PSU due to a short circuit on the board, or maybe the broken P8 socket?
I had severe issues to plug P8 back and after ten minutes or so of trying to get it in I saw the metal pins of the socket were all broken of the socket. I think that was the reason why I can't get it in, but who knows? Maybe I did it myself? But I'm not aware to used such a force.
Reply 1 of 4, by CharlieFoxtrot
I believe the connector is officially called Molex 15-48-0106.
Someone correct if I'm wrong, but that's what I've written down 😁
Reply 2 of 4, by PC Hoarder Patrol
Iarsin wrote on 2023-10-21, 13:25:
Hi, is there a possibility to repair or find a replacement part for the broken P8 socket on the Mainboard? […]
Similar question recently asked - Replacement for AT P8/P9 pin power connector
Reply 4 of 4, by Iarsin
BTW, is it normal that P8, Pin 5 gnd isn't connected in 5160? The hole of the plug is at position 5 empty without a cable connected, without any metal contact or pin.
