First post, by jasa1063
I posted back in March of this year about my Juko Nest N3 NEC V30 10MHz build that I acquired:
Re: Juko Nest N3 XT system w/NEC V30 Acquisition/Build
Some of my benchmarks came up a bit short against the legendary Anonymous Coward's "V'ger XT. I wanted to get to the bottom of what made my system slightly slower and I think I finally have those answers. All of my benchmarks now equal or exceed that system. What has changed in the last 7 months? Changing the video card to a Diamond Speedstar ET4000, a bit more testing and some key software tweaks. I had erroneously assumed the system was already running at zero wait states reading from the wait state configuration register at port 70H which always came back as zero. I came to find out that the register is write only. It was only after trying different values that I actually was able to tweak the system to the point it made a real difference. It turns out the memory is at zero wait states, but the ISA bus is set to 3 wait states in the default configuration. I was able to get the ISA bus to 1 wait state and this made a big difference as the benchmarks will show. The 2nd thing was tweaking the memory refresh rate. I now use a value of 500us which is stable and results in measurable increase in overall system performance.
I decided to move this motherboard from a tower to desktop computer case. I really think XT class systems belong in desktop case. This of course did not change the performance, but I now think it has the proper ascetic look. Here is a picture of the new case.
    1.91 MiB
    Juko Nest N3 in a desktop case
Reply 1 of 11, by jasa1063
Norton SI 4.5 & 6.01 results:
    1.69 MiB
    Norton SI 4.50
    1.54 MiB
    Norton SI 6.01
Reply 2 of 11, by jasa1063
Topbench 0.40b results - My Topbench score is now 16!
    1.48 MiB
    Topbench 0.40c
Reply 3 of 11, by jasa1063
CheckIt 3.0 results:
    1.38 MiB
    CheckIt 3.0 system
    1.29 MiB
    CheckIt 3.0 video
    1.25 MiB
    CheckIt 3.0 hard drive
Reply 4 of 11, by jasa1063
3DBench 1.0 results - I managed to bump up the score 2.3 FPS!
    1.79 MiB
    3DBench 1.0
Reply 5 of 11, by jasa1063
PCTools SI 8.0 results
    1.45 MiB
    PC Tools SI 8.0
Reply 6 of 11, by jasa1063
3Quarterdeck Manifest 1.13 results - The EMS memory results went up a good amount
    1.62 MiB
    Quarterdeck Manifest 1.13 System memory
    1.62 MiB
    Quarterdeck Manifest 1.13 EMS
Reply 7 of 11, by jasa1063
Landmark 2.0 & 6.0 results - I still had to start Landmark 6.0 at 4.77MHz to get it to start without freezing then kick it back up to 10MHz
    1.88 MiB
    Landmark 2.0
    1.95 MiB
    Landmark 6.0
Reply 8 of 11, by jasa1063
Core Test 3.03 - The is the biggest jump. I now almost get 1MBs throughput on the XTIDE Compact Flash adapter!
    1.24 MiB
    Core Test 3.03
Reply 9 of 11, by jasa1063
Well I think this brings this computer's journey to an end. I am really happy with the results. I just goes to show you just need to keep at something until your brain can think it through!
Reply 10 of 11, by jasa1063
I am also uploading the set of tweaking utilities I used. DRAM simply sets the memory refresh period. In my case I use DRAM 500 for a 500us memory refresh period. Also included are 3 small utilities created with debug for tweaking the wait state configuration register at port 70H. WS0 tries to set everything to zero wait states, but completely locks up my computer. I am only including it for testing purposes in case anyone else has better luck. WS1 sets the the ISA bus to 1 wait state and RAM & ROM to zero wait states. This is what I use for when I boot the system. WS3 is simply the default state as if no tweaks were applied. I figured this out during my testing. Please note the 3 wait state utilities should just be used with a Juko Nest N3. I also have a Juko ST motherboard and while that uses port 70H, just like the Nest N3, they are slightly different in my experience.
    Juko Nest N3 Tweaking Utilities.zip
    18 KiB
    21 downloads
    Juko Nest N3 tweaking utilities
Reply 11 of 11, by jasa1063
I just checked and the webpage with Anonymous Coward's "V'ger XT is no longer online. Here is the last snapshot from archive.org in case you want to look at that page.
https://web.archive.org/web/20230504111227/ht … misterzeropage/
