First post, by McDuck88
Hi everybody!
I've got a Plextor PX-40TS SCSI drive that doesn't do anything except flashing the DISC and ON/BUSY LEDs on the front. The drive shows up on the PC as normal, but it doesn't open the tray. I need some advice what could be the problem with the drive.
Reply 1 of 2, by Disruptor
Hi,
my PlexWriter once had the problem that it was non-working but it still identified on the SCSI bus - with 2 flashing LEDs.
I let it in a box for years... but then I tried a firmware flash. That helped...
Reply 2 of 2, by McDuck88
Disruptor wrote on 2023-10-22, 17:00:
Hi,
Thanks for the tip. Firmware update really did made the drive working again. Thanks! 😀
