Which simms for 386DX40
First post, by gmc
Got my hands on 386DX40 motherboard which I'm trying to bring back to life.
First issue is it's missing RAM. Found the m/b on this site :
https://theretroweb.com/motherboards/s/gemlight-gmb-386umc
and it takes 30 pin SIMMS. If for example I want 2MB then
Bank0: (4) 256K x 9
Bank1: (4) 256K x 9
So I need 8 x 256K 9 chip 30 pin SIMMS?
I've seen a few photos of the motherboard with 3 chip SIMMS? Will either work or does it have to be 9 chip?
I might also go 4MB which might be more cost effective?
(4) 1M x 9
It
Reply 1 of 6, by Grzyb
That's 9 bit = 8 bit + parity.
So, not necessarily 9-chip, 3-chip modules should work as well.
1M modules are plentiful and cheap, I would go for 4 or even 8 MB.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 6, by Nexxen
gmc wrote on 2023-10-26, 17:01:
Got my hands on 386DX40 motherboard which I'm trying to bring back to life. […]
Bank0: (4) 256K x 9
Bank1: (4) 256K x 9
(4) 1M x 9
It
No, you don't need 8x256KB.
9 chips have better compatibility, but I never had issues with 3, not a reliable source though.
If Ram configuration table is correct you can mount up to 64MB.
4x1MB is better.
In time you can buy more, with some luck, at a good price.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 3 of 6, by gmc
Thanks for the info. Trying to remember all this info from almost 40 years ago 😀
Off to find some chips.
Reply 4 of 6, by Disruptor
With 128 KB of L2 cache, I recommend to use 4, 5 or 8 MB of RAM.
The cacheable area of a 386DX/486 with 128 kB cache size is 16 MB.
Reply 5 of 6, by AlexZ
386DX40 deserves 8MB RAM. May protected mode games require that and windows 3.1 is faster as well. 16MB RAM isn't that useful as the software usually requires a faster CPU as well. 16MB is more suitable for a 486DX2/66.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 6 of 6, by Jo22
OS/2 loves to work with RAM, on about any system. 🙂
~6 to 8MB was the lower minimum that the developers had recommended (for OS/2 of early 90s).
It often was being bundled with 4 MB PCs, though, which it struggled with (like Win 95 did).
About 12 MB onwards made it run smooth, I believe.
Edit: Windows for Workgroups is similar, maybe, if all the networking features are enabled.
The sharing of resources (printer, files) is memory taxing, too.
I remember reading about WfW mail servers in offices being run on fast 486 PCs with lots of RAM (up to 24 MB).
There was a picture of such a server hidden in a closet.
