First post, by rlsuth
Hi, I'm new to all this, so please bear with me.
I installed Dosbox and the CVS compile and then managed to get Hyper 3-D Pinball installed. However, when I try to run the game, I get the following problem:
See attachment
I've searched the forums and didn't see anything related, but there was a post on SVGA extensions? but I really didn't follow what it was saying.
Can anyone help me here?
    44.88 KiB
Reply 2 of 5, by rlsuth
Thanks for the reply.
The cycles made no difference.
I then downloaded dos32a and copied the sb.exe and dos32a.exe files to the game directory and tried to run the game using the command "sb -r 3DPINBAL" but since the game is initiated by a bat file, containing RUNCD, it game an error in opening.
I then tried renaming DOS32A to DOS4GW, and got exactly the same error as before. 🙁
Has anybody got this game to run?
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
> Tried every combination I could, and still nothing
Do you still get the DOS4/GW error, or does dos32a
display this (similar) error?
I don't have the game, but some general things to try:
- try ems=false/xms=false in dosbox.conf (or combinations)
- disable the sound
- load the game WITHOUT univbe
- use the full core/dynamic core (dosbox.conf)
- try the debugger-enabled version of dosbox (does more
logging output and cpu-checks)
If you're handy with a debugger, you could see where the
divbyzero comes from (basically set a breakpoint at
1e0:10cc, ie. BP 1e0:10cc, and see what opcode triggers
the exception, and try to get an idea where the zero
comes from).
Good luck 😀
