First post, by CadMasterAdam
Hi team!
Installed and have been playing Beneath a Steel Sky. Just past the first level and am faced with the following crash every time I try to go to the Left of this below image.
I'm using the archive program from: https://www.dosgamesarchive.com/download/beneath-a-steel-sky
What am I doing wrong? can anyone replicate this. attached is the current save file you may use to get to the spot I'm currently at in the game.
see this URL for a link to a 5 second looping video i made of the actual crash:
https://photos.app.goo.gl/QHC5wh2rdGzhgofSA
CURRENT SETUP
  • P2-200 MMX (real wafer)
    RAGE PRO TURBO PCI
    16MB ram
    win98se
    8GB HDD
AUTOEXEC and CONFIG not included. I understand from another VOGONS post that Beneath a Steel Sky maps its own memory and does not rely on those files to run correctly.
Thanks and BEST REGARDS!
    sky-save just before crash.zip
    14.14 KiB
    25 downloads
    zip contains current save file for the posted query
    61.05 KiB
    screen grab from windows just before crash
