STB Voodoo 3 card dead.
First post, by Lyriell
Hi guys,
I just got my hands on a Voodoo 3 2000 today, and it everything was hunky dory... but I was having some issues with Final Fantasy VIII stuttering and I thought I'd update the firmware all around... PC bios/video card etc.
I was on version 1.01 (or something) and I took a backup of my rom... but after flashing and rebooting my machine could not detect the video card.
After putting in my old video card, I went into the flash utility and attempted to write my old rom back in place, unfortunately I seem to get the following message.
'Unknown flash Eeprom manufacturer. (man. ID: 00h, Dev. ID: 00h)
I've tried every version of the flash room util I can, and I've tried using the /reset command as well with the flash tool.
Am I stuffed, is there no way to get this working again?
Reply 1 of 3, by c0burn
You may have to pull the chip and program it using an external programmer. Sounds like ti could have gone bad, and indeed a bad BIOS is a fairly common voodoo failure point - for example see https://www.youtube.com/c/vswitchzero - he has videos around troubleshooting this kind of issue.
Reply 2 of 3, by analog_programmer
If you use second PCI videocard, change the PCI slot for it and try flashing again. Or make a DOS bootable diskette with "autoexec.bat" plus flasher program and BIOS dump for blind-flashing.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 3 of 3, by technokater
I recovered my bricked V3 3000 AGP by booting with a PCI card, then flashing the BIOS with the correct version. It should have created a SAVE.ROM file with the original BIOS. However, the official 3dfx tools dump the old BIOS first to SAVE.ROM (i.e. overwriting any existing file of that name), erase the BIOS and *then* check the provided ROM to flash. That's how I ended with a deleted BIOS on my V3.
