First post, by Grzyb
Around 1994, I encountered this image file...
no idea about its origin - perhaps a drivers disk of some graphics card?
I've found it again on the modern web, unfortunately destroyed by lossy compression.
Anybody has the original version?
The attachment orchid.jpg is no longer available
Nie rzucim ziemi, skąd nasz root!
Reply 1 of 4, by dominusprog
I believe Orchid made sound cards.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by Grzyb
dominusprog wrote on 2023-11-13, 18:29:
Yes - graphics, sound, and memory cards.
I suspect the image I'm looking for came with a graphics card, though - the "640x480x256" suggests some graphics demo, or diagnostics?
Reply 3 of 4, by Grzyb
Success!
Found the original image.
But still wondering where it came from - any idea?
The attachment orchid1.gif is no longer available
Reply 4 of 4, by mkarcher
Grzyb wrote on 2023-11-13, 18:59:
Many SVGA cards came with driver disks that included drivers for common DOS applications, and some refresh rate setup and mode test tool. It sounds very likely that this image was presented when you tested whether the 640x480 256 color mode works on your monitor at the currently configured refresh rate.
DOS Days has some info on Orchid graphics cards. I noticed that they made an "improved PGA clone". The prime resolution of the PGA is 640x480x256, which fits perfectly to that image file. This might also explains why we don't see 800x600x16 versions of it, as the PGA only supported this one resolution (and CGA-type resolutions in CGA compatiblity mode).
You might be able to contact Greg Marshall, a designer of the Orchid PGA card (see https://wa-chur-ed.com/looking-back/ ) to ask whether the image was included with the Turbo PGA.
