L2 cache problem 486
First post, by Frank Grudge
Benchmark programs are tellling me my L2 cache is not working, ive noticed 2 absent 74244 ics on my board. (Also some decoupling caps) Comparison from the retroweb.
Could it be possible L2 was never enabled?
I am thinking to fit these 2 chips . Why are they missing?
Board = 4SGS-3VL
Thanks
Reply 1 of 8, by jakethompson1
Is your tag ram (down by the first VLB slot) populated?
Reply 2 of 8, by Frank Grudge
jakethompson1 wrote on 2023-11-16, 08:14:
Yes it is populated identical to the rest of the L2 chips w61c256a
Reply 3 of 8, by majestyk
Your mainboard is configured fpr 256K cache with 8 x 32Kx8 chips. Jumpers 1,2 are soldered so cannot select any option with 512K or 1M L2 cache.
This might be a case of "fake cache" and they spared the buffer-drivers as well.
Have a look here:
Fake cache board, reboot loop after adding real cache
Those "dt" cache chips don´t look very common and the brand "Azza"...well...
So just replace the 9 chips, add the jumpers and the two buffer-drivers 74F244. (Of course you can give the current chips a chance first after adding the buffers.)
Reply 4 of 8, by mkarcher
majestyk wrote on 2023-11-16, 14:23:
The marking of the cache chips looks like real cache chips. The "integral" symbol followed by "dt" is a manufacturer logo of IDT (Integrated Device Technology), and I am very confident I own working chips with that branding. The IDT 71256 is a real product, and the latest datasheet for them is Renesas branded. This of course doesn't mean that this branding can not be applied to fake chips as well.
Without the 74244 address buffers, the cache definitely will not work, though. I suspect someone tried to add cache by installing the SRAM, and it never worked.
Reply 6 of 8, by Tiido
On the second photo in first post, one chip has its pin1 bent and not in the socket.
Those buffers next to sockets definitely need to be there for things to work.
Reply 7 of 8, by jakethompson1
mkarcher wrote on 2023-11-16, 19:42:
Any thoughts why this board vendor populated the jumpers to hardwire the board for 256K, double bank cache, but didn't put those chips on there?
I have seen some boards where they omitted chips and replaced them with eight diagonal resistors; could the board vendor have done that instead or is the need to be able to tri-state those outputs inherent in the design?
Reply 8 of 8, by mkarcher
jakethompson1 wrote on 2023-11-17, 01:03:
This is just guesswork, but you asked for "any thoughts": The vendor shipped the board in the 256K an 0K configuration, and they only omitted components in the "0K" edition that had a significant cost in the BOM. Jumper wires might be expensive to install, but they are very cheap to buy, so the vendor didn't think about removing them when they specified the 0K edition.
The '244 is a unidirectional buffer, and at that location on the board, I am very confident that it is used a address buffer, input is the processor address bus, and output is the cache address pins. As the cache chips are the only thing on the output side, and the 0K edition doesn't have the cache chips installed, the tristate option is definitely not required. As long as loading of the address bus is not an issue, the '244 chips can be replaced by 8 jumper wires each.
