First post, by AlessandroB
I installed the card you see in the photo in my PC as a support for retrocomputers (Asrock FM2A68M-DG3+) and after a few attempts (I don't even know if I managed to install the correct driver) by connecting the HD in the photo I can see it, but there is no way to make it read the floppies in the LS120, it always tells me "insert disk". Does this particular floppy drive require an IDE controller with special features? This same floppy works if connected externally in an old USB2.0->IDE box used for CD-ROMs
Reply 1 of 16, by fosterwj03
I've had nothing but terrible using an internal LS-120 drive with Win 10. I ultimately gave up. USB seems to be the way to go.
Reply 2 of 16, by Disruptor
fosterwj03 wrote on 2023-11-16, 14:50:
Same. Even with an SATA-to-IDE adapter I had no success.
Perhaps the problem is that the LS-120 does not want to talk (U)DMA.
I'm using an USB-to-IDE adapter now.
Reply 3 of 16, by BitWrangler
Try a CDROM or other optical drive on that controller, maybe it doesn't do diskchange right.
Reply 4 of 16, by darry
AlessandroB wrote on 2023-11-16, 13:55:
I had to jump through a few hoops to get mine working.
Does your's constantly blink it's LED and make it's power on sound in a loop ?
Mine did that when it was unintentionally forced into DMA mode.
See also
Re: Options for connecting internal 5.25 / 3.5 / ZIP drives to modern system
Reply 5 of 16, by Grzyb
IDE devices other than HDD require ATAPI, right?
And many controllers lack ATAPI support, especially those with RAID...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 6 of 16, by AlessandroB
BitWrangler wrote on 2023-11-16, 16:17:
i will try tomorrow, in fact my ls defect to eject the floppy and when is ejected do not work the internal mechanism... can be the same as the cd-rom?
Reply 7 of 16, by AlessandroB
I hate external ones, I rather integrate the electronics contained in the external box internally and arrange the LS120 internally anyway
Reply 8 of 16, by fosterwj03
Back when I explored the issue a few years ago, the forums concluded that the problem was in the MS super floppy driver. MS seems to have fixed the issue for USB interfaces, but not ATAPI interfaces (including SATA adapters).
A previous poster noted that UDMA might be a factor. Unfortunately, SATA adapters typically default to UDMA modes.
Reply 9 of 16, by AlessandroB
ok, i think i will sell and buy i regular usb floppy…
What limitations do cheap USB floppy drives found on eBay or Amazon have?
Reply 10 of 16, by Disruptor
They probably may not read DD disks.
My USB floppy does.
Reply 11 of 16, by AlessandroB
Disruptor wrote on 2023-11-17, 17:42:
My USB floppy does.
720kb floppy? in my personal setup i have no one, does not matter for me.
Reply 12 of 16, by Grzyb
AlessandroB wrote on 2023-11-17, 20:05:
For a long time, 720KB diskettes were common as distribution media.
Some day you may encounter such a disk, and want to archive it...
Reply 13 of 16, by AlessandroB
I can use one on my 8 retro-IBM for that, but i need a easy way to write something on a 1.44 floppy from my win10 PC.
Reply 14 of 16, by ElectroSoldier
Its an ATA controller that drive requires ATAPI.
You just need a PCI controller card that adds ATAPI support not UDMA RAID.
I think the Promise ATA 66 was a proper ATA controller, there were a couple of others but I cant remember their names. Ill try and dig mine out.
Reply 15 of 16, by AlessandroB
ElectroSoldier wrote on 2023-11-19, 00:41:
thanks, let me know please. so we can still save this drive
Reply 16 of 16, by AlessandroB
this??
