First post, by JF_Sebastian
Hey folks,
i got my AMD K6-III 450MHz today and of course installed it straight away. Unfortunately, the system keeps restarting after the BIOS almost every time I switch it on. Following settings are set:
- BIOS: 0270-2
- Vcore: 2.2V and tested up to 2.5V with no change
- Multi: 6
- FSB: 66MHz runs with restarts after bios and 75MHz were tested but system hangs after the bios
I have unplugged all cards and stuff except the graphics card and found out that the system boots when I have also unplugged my USB header with keyboard and mouse. (?)
Is it possible that my power supply seems to have not enough power on 5V rail for the K6? My power supply is an old seasonic with 200W which should supply 20A @5v (says the type plate 😁)
Does anyone know current power supplies which offers up to 25-30A on 5v rail with an additional -5V rail?
I am so frustrated *argh*. I would really appreciate some help to make it work.
Best regards,
JF
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 1 of 9, by Repo Man11
Try removing and reinserting your RAM. If you have more than a pair of SIMMs installed, try it with just one pair installed, and if the problem persists, try the other pair instead. Maybe inspect the RAM contacts and the RAM slots for any corrosion?
Reply 2 of 9, by Horun
Does the board work with an original listed supported CPU (like P-133, P-200MMX) ?
Reply 3 of 9, by JF_Sebastian
Thanks for your replies!
MoBo works fine and 100% stable with P133 and P200MMX. Both here on my table. Its mysterious. Just with the K6-III the MoBo has a problem.
@Repo Man11
I'll check, but it's strange that the other CPUs are running fine.
Any other ideas 🙁 Can the power supply really be ruled out as the cause of the problem?
I took a closer look at the USB port. Normally a USB hub is plugged in to the USB header, which is powered externally. If I leave the hub plugged in and remove the external power supply, the reboot is even faster when the BIOS is first displayed. When I leave the peripherals connected directly to the header without the hub, the system restarts after BIOS boot as before. So it seems the 5V supply has an impact to the system.
Best regards and thx,
JF
Boot Up or Shut Up!
Reply 4 of 9, by JF_Sebastian
Repo Man11 wrote on 2023-11-19, 04:15:
I have checked the RAM and have additionally decreased timing to 70ns instead 60ns. No effect.
Best regards,
JF
Boot Up or Shut Up!
Reply 5 of 9, by Repo Man11
"I have unplugged all cards and stuff except the graphics card and found out that the system boots when I have also unplugged my USB header with keyboard and mouse. (?)"
Have you tried using a PS/2 mouse and keyboard? Assuming that you will be using Win9x, a PS/2 mouse is a good idea anyway since it also works during setup, and when you boot into Safe Mode.
Reply 6 of 9, by the3dfxdude
JF_Sebastian wrote on 2023-11-19, 03:55:
This is easy to check. Install only the minimum hardware for the most stable configuration, turn the system on, and probe the 5V supply rail for voltage with a voltage meter. Turn off, add a card and turn on and probe again and repeat. This doesn't check for ripple, but anything too low you'll see. With ripple, it's better to check with a scope, but you should see more random instability in devices connected.
Reply 7 of 9, by JF_Sebastian
Repo Man11 wrote on 2023-11-19, 15:02:
That's true and with PS/2 and AT keyboard the system boots much more often. So far I have connected keyboard and mouse via the original ASUS USB header and it has worked fine with all other CPUs - the MoBo even has USB support in the BIOS. This is great and I can use a USB switcher to share keyboard and mouse from my everyday PC and the retro build 😉 But even with PS/2 and AT keyboard the system is unstable.
In the next few days I will receive a TAGAN TG480-U01 power supply from a friend. This can supply more than enough current on the 5V and also has a minus 5V rail. I think this is a good candidate to check if the power supply is the root of all the trouble. I hope so! 😁
Best regards and have a successful start to the week!
JF
Boot Up or Shut Up!
Reply 8 of 9, by JF_Sebastian
the3dfxdude wrote on 2023-11-19, 16:07:
Thank you for your good suggestion. Thanks to my friend, I prefer the lazy solution with a working power supply. 😁
Boot Up or Shut Up!
Reply 9 of 9, by ahyeadude
I have the same board and also the same issue, but with a P133. It would start to post, beep, then reboot, post, beep, in a loop. Sometimes it would take 3 or 4 cycles before it would proceed and work normally. This would only occur on a cold boot when the computer had not been on for some time. I figured it was a 5V power issue of some sort. However, my 5V rail measured 5.06V using a voltmeter.
After continuing to have the issue with all peripherals removed, I swapped PSUs. This instantly fixed the issue. The 5V rail on the ATX power supply I was using must be unstable during the high load transient condition that occurs during cold boots. This motherboard must also be very sensitive to it. The same problematic PSU powered another socket 7 board just fine.
