First post, by Hojo82
So I received an FX 5500 that is showing the BIOS initialization screen with bad text color in the foreground and background at regular intervals. I’ve removed one obviously bulging cap, but I also noticed that some of the surface mount chips were ripped off. I can deduce the values of the missing decoupling caps, but I’m also missing a couple of resistors as well.
The missing resistors are on the back of the board, namely R352 and R353. I’ve attached pictures of the board for reference and boxed the two missing resistors.
Basically my question is this: does anyone have this Gainward FX 5500 board who can look at the values printed on those chips and let me know? And if not, does anyone have any guidance for what the values might be? The only other thing I know is that the lower right pad of the four goes to ground.
    817.4 KiB
    1.68 MiB
Reply 2 of 2, by Hojo82
Karbist wrote on 2023-11-21, 22:15:
https://www.ebay.co.uk/itm/235165470094
4th picture but It's not very clear, 20A ,30A or 70A.
Thank you! I've contacted the seller...hopefully they'll respond telling me what the values are.
