First post, by mimdalli
Hello,
I have a very old executable which I still need to use for my work. It is developed special for my work sometimes in 90's, there is no alternative. Unfortunately the executable checks the version of dos and if the version mismatches I get an error (see attachment). I think it checks the answer of the command "ver".
So I am still using window98 in a virtual machine, however it is very difficult to exchange files between the host OS and windows98. I want to use it within dosbox but it gives the version mismatch error. So I am wondering if it is possible to make a patch or something like that to dosbox, so that it gives the same version number as a windows98 ms-dos prompt, perhaps my executable run well?
Thank you.
    14.65 KiB
    Fault on dosbox version mismatch
Reply 1 of 2, by zirkoni
No patch needed. DOSBox already has a command to set the reported DOS version.
Example (this will set it to 6.22):
ver set 6 22
EDIT: I'm not sure about what DOS version Win98 has, 7.1 maybe?
https://youtube.com/@zirkoni42
Reply 2 of 2, by DrMedWurst
zirkoni wrote on 2023-11-24, 17:49:
Yes, Windows 98 FE & SE both use DOS 7.1.
mimdalli wrote on 2023-11-23, 21:48:
DosBox usally reports DOS 5.00 on startup.
If the software is running on a Windows 98 VM, a "ver set 7.1" should make DosBox return DOS version 7.10 and it should work.
64K RAM SYSTEM 38911 BASIC BYTES FREE
