First post, by victormun
Hey guys!
I'm currently working on rebuilding my old P3 (533Mhz) build from 1999 and I'm running into a weird issue: my motherboard (A-Trend ATC-6240V) reads every single SDRAM DIMM as 128Mb. According to the MOBO manual, these are the allowed sizes for each DIMM-slot:
  • Bank0/DIMM1 - 8/16/32/64/128/256/512MB - 512MB
  • Bank1/DIMM2 - 8/16/32/64/128/256/512MB - 512MB
  • Bank2/DIMM3 - 8/16/32/64/128/256MB - 256MB
  • Bank3/DIMM4 - 8/16/32/64/128/256MB - 256MB
    This sums up to 1.5Gb of max RAM.
These are the configs I've tried:
  • d0: 128Mb
  • d1: 128Mb
  • d2: 128Mb
  • d3: 128Mb
    This gives me 512Mb, which is correct.
  • d0: 512Mb
  • d1: -
  • d2: -
  • d3: -
    This gives me 128Mb.
  • d0: 512Mb
  • d1: 256Mb
  • d2: -
  • d3: -
    This gives me 256Mb.
Anyone knows how to maybe fix this? I've looked all over the BIOS for some kind of limiter or multiplier or something but I can't seem to find anything.
Thanks a lot!
Reply 1 of 7, by Deunan
victormun wrote on 2023-11-24, 10:27:
In theory. Not all combinations will be supported, plus there's the cache size and configuration (as well as particular chipset type) that might limit the amount of usable RAM.
As for DIMMs, keep in mind there are single and multi-rank modules. Chipset might not be capable of working with newer, higher capacity RAM chips - and only recognizes part of the available memory. Frankly I have been using 128MB and 256MB sticks on Socket7 mobos as 32 or 64MB because it's easier for me to find cheap 128MB 133MHz sticks than 32 or 64MB ones rated for 66 or 100MHz. As long as it works and passes memtest I'm happy.
512MB sticks were a problem for Athlon/Duron mobos, I remember that trying to upgrade RAM in these systems near the end of their useful life was a bit of a lottery. I don't have much experience with Slot1 mobos but I would assume these had similar issues.
Reply 2 of 7, by victormun
Thanks for your insights!
I've been digging a bit more and have found that the Apollo Pro133 Chipset can only read a maximum of 128Mb per DIMM. I guess that kinda answers this question.
Reply 3 of 7, by victormun
Sorry for double-posting but there is a question that comes to my mind: if 128mb is the actual max limit of this chipset... How come that the board manual talks about 256+ DIMM configurations? And what is more: it states that the maximum RAM is 1.5gb. This would be impossible to achieve if 128mb per DIMM is the limit.
Reply 4 of 7, by The Serpent Rider
It should work at least with dual-rank 256 Mb modules, i.e. 16 chips, excluding ECC.
Reply 5 of 7, by pentiumspeed
Did you know that high density 256MB modules are not supported on this one?
What you need is low density 256MB modules for the 440BX chipset.
256MB low density is 16 chips total per module.
Cheers,
Great Northern aka Canada.
Reply 6 of 7, by Repo Man11
dionb goes into detail in this post: Computer only detects half the RAM
I hadn't realized that there was this limitation of the Apollo Pro 133 chipset, but realistically that's a Windows 9x platform so you can easily have well more than enough RAM.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 7 of 7, by AlexZ
VIA VT82C693A (Apollo Pro 133) is a poor choice for PIII due to its abysmal memory performance. It is partially fixable by wpcredit chipset register editor in Windows, but I would still highly recommend getting a 440BX board.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
