First post, by schmatzler
I got this X850XT from an eBay seller who had the great idea to put a cooler from another model on it.
The cooler had two heatpipes directly sitting over two of the memory chips, so the seller just removed the two heatsinks from the chips.
Lesson learned: Some people are idiots.
The attachment x850xt.jpg is no longer available
The card had some graphical corruption in games which went away when I pressed my fingers on the chips, so this was a classic problem with the BGA solder balls losing the connection.
I've decided to reflow both of the memory chips with my hot air station but I went a little too hard with the heat and one of them released its inner secrets violently.
Lesson learned: I am also an idiot.
The card still tries to put out a picture, it just looks like this:
The attachment x850xt-glitches.jpg is no longer available
So it basically works, I just need to source these BGA memory chips and replace at least one of them.
I've searched far and wide but I can't find any source that sells these chips (apart from some chinese websites where you have to buy 10.000 of them).
They are K4J553230G-BC14:
The attachment x850xt-memory-chips.jpg is no longer available
Maybe there are compatible models that are a drop-in replacement or some cheap cards that also have them?
I really don't want to throw this card into the trash, it's a great card (very fast for 9x) and needs to be saved.
Reply 1 of 9, by schmatzler
Looks like I'm getting old (or at least my eyes do).
That's not a "0" on the chip, it's a "Q".
So the chips on there are K4J55323QG-BC14.
These are easily available, including the stencils for reballing.
I've ordered some from China and will update this post when they arrived and I (hopefully) fixed this card.
According to the datasheet, these are the variants of the chips:
The attachment datasheet.png is no longer available
Maybe upgrading to the BC12 variant would be an option, too? 😉
Reply 2 of 9, by ciornyi
Does gpu heatsink is on all time basis ? As with such cooling your gpu will die quick
DOS/95: PII266/128mb/AWE64/TNT
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/2GB/SB X-fi/HD6850
Reply 3 of 9, by schmatzler
No it's just temporary. When it's fixed I'll put a passive Zalman heatsink on it and a big fan.
Reply 5 of 9, by schmatzler
That's good to know. So the seller even removed the heatsinks on the memory chips and put smaller ones on them.
It just keeps getting worse. 😁
Reply 7 of 9, by analog_programmer
giantclam wrote on 2023-11-24, 13:42:
Actually, I'll reneg on that ... the blue heatsinks mark it as a Palit -> https://www.classicvga.com/product-page/palit … ddr3-256bit-agp
These pictures with Zalman VF900-Cu cooler and blue heatsinks looks like aftermarket cooling modification.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 8 of 9, by giantclam
analog_programmer wrote on 2023-11-24, 15:53:
Could well be the case ~ I remember 'kits' that were around back in the day like that. The reference design is easy to spot by way of the VRM layout ..
I imagine the changed cooler was from an x800 GTO ..
Reply 9 of 9, by analog_programmer
giantclam wrote on 2023-11-25, 00:32:
I still have the same Zalman VF900-Cu cooler kit. The RAM heatsinks are exactly the same as those on the pictures in blue color. The only missing part from the cooler kit on these pictures is the manual controller for fan rotation speed and its 3-wire cable.
