First post, by songoffall
- Oldbie
Where I live it's hard to get hold of new floppies, and a Gotek, unless ordered from Amazon, would set me back $200, and Amazon orders take up to a month to show up.
So I mostly have to make do with old floppies I can scavenge. My family had the bright idea to donate my own floppies to a school.
So even floppies that were supposed to be good and remained untouched for decades would inexplicably fail, and the file names, disk labels and everything was just garbled rubbish.
So, for those unaware, there's several ways in which floppies fail.
1. Physical damage, obviously. Sometimes can be seen by the naked eye. In a more terrible case, a dirty or defective drive head will carve concentric grooves in the disk. So clean your drive heads regularly. And, while you're at it, put some lithium oil on the helicoid once in a while.
2. Deterioration of the magnetic material. The magnetic material on the disk that holds the data deteriorates - by either losing its magnetic properties or just flaking off the disk and sometimes accumulating on the drive head.
Both these conditions are irreversible and the disk can no longer be trusted to hold important data or do, say, a BIOS update because the failure tends to spread over time.
3. Dirt and dust. Sometimes the disk can clean itself. Manually cleaning the disk, at least in my case, did not reliably solve the issue.
4. Magnetic damage. Either the disk demagnetizes over time or strong magnetic fields mess up the data. Usually, but not always, a format a: /u is enough.
So about 80% of the disks I got this time refused to be formatted, and almost all of them had some garbled data and labels.
I was about to give up on them, but then decided it was time for some sysadmin voodoo, so I did the usual Norton disk doctor + Scandisk + Quick format + Full format routine. Currently,
- 5 disks are dead + 3 with visible physical damage
- 4 disks are alive, but with bad blocks
- 13 disks are alive with no bad blocks, and I have scanned and formatted them repeatedly to be sure they are reliable.
- 25 more disks to go, but I'm not too hopeful with these
But it seems like in some cases even magnetic damage can cause disks to refuse being formatted and after some tinkering they get better. I wish I had a large magnet to see if it helps.
Most of the time this isn't worth the effort, getting new disks or a Gotek is the way to go. It's just me experimenting with old disks, don't be me 😁
What's your experience with old disks?
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
