First post, by DaveDDS
- Oldbie
I'm trying to rebuild DosBox - want to keep it small(ish) so I'm not trying to
use DosBox-X - I'm using SVN from DosBox.COM
I have it building (with VS2010exp) and working, however I need to add the
NE2000 patch. The version of PATCH.EXE I managed to find always seems to error-out,
so I'm looking to just apply the patch(s) manually...
The problem I have is that the two NE2000 patch files I have found:
ne2000_16_05_2017.diff
ne2000_27_11_10.diff
both modify a file called "configure.in" which does not appear anywhere
within my project directory.
Can anyone explain what gives?
(My main goal is to fix certain line/TAB entry and file timestamp errors which
drive me a bit nuts (and X hasn't fixed) and maybe eventually do an Android
port with support for a RamDisk (so I don't have to constantly rewrite flash
with compiler TEMP files!)
Dave Dunfield - https://dunfield.themindfactory.com
** I'm pretty sure that before I was out of commission in 2019-20 I did have
"Megabuild 6" (which included the NE2000 patch) building - but between then
and now - I lost a LOT of what I was working on - I get compile errors for
"missing" things now when I try to build it.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
