First post, by Kahenraz
I bought a Voodoo 5 5500 PCI (with DVI, flashed for PC) which appears to be defective. When running games and benchmarks, the display drops to a text mode pattern before locking up completely or hard resetting itself.
Does this look like a memory problem or an issue with one of the VSA-100 chips?
I recorded the issue as it appears in both Windows 98 and XP:
https://youtube.com/shorts/xtIDw-eaFic?si=OdylhfBvAb23GVpF
https://youtube.com/shorts/6crSCIFBTzQ?si=UnFrFU4NI-TurYgH
390.93 KiB
268.31 KiB
Reply 1 of 4, by mwdmeyer
I’ve not seen this before. Can you set it to use one vsa100 chip and try again? It’s in the driver settings.
Reply 2 of 4, by Kahenraz
Games and benchmarks seem to work fine in single-chip mode. It's only when using both chips that the fault occurs.
The card has a slight warp where it's drooped due to gravity in an upright chassis. Maybe there's a cracked solder ball under one of the BGA chips?
Is the primary VSA-100 chip on the left or the right?
Reply 3 of 4, by Kahenraz
The seller would not negotiate a partial refund, so I ended up returning this card instead of attempting a repair. It's a pity, because I really wanted to fix it. However, accepting the risk and cost of repair on top of what I paid for it with what was supposed to be a working card is untenable.
Reply 4 of 4, by mwdmeyer
That is a shame, but it is the right thing to do, although with all retro hardware it does die. But if you purchased working, then it should be working.
