First post, by envagyok
I don't know deeply the game Doom.
I read, for music Roland SC-55 is the best choice, i had this with mpu-401.
I had yamaha mu-50 too.
But what sound card give the best quality for sound fx?
Gravis ultrasound, or sound blaster, sound blaster pro/pro2, or sb16/awe32/awe64, maybe pro audio spectrum, ensoniq vivo?
My second question, for doom exist patch or mod to achieve better sound fx quality?
Thanks any helping word .
Reply 1 of 3, by Joseph_Joestar
As of late, I've come to appreciate the softer low-pass filter of a SBPro card for Doom 1&2. You can listen to some samples recorded by James-F here. Certain SBPro compatible cards have this filter as well, such as the ESS AudioDrive 1868F and OPTi 82C930.
Another thing to check for is proper stereo orientation. Some SBPro compatible cards flip the stereo in Doom, so sounds that are supposed to come from your left speaker end up coming from your right one. Again, James-F did a thorough analysis on this and his results can be found here.
Reply 2 of 3, by Shponglefan
IIRC, Doom's samples are 8-bit 11KHz recordings. They're already quite limited from an audio quality perspective. Low-pass filtering used in some sound cards (per Joseph_Joestar's post) removes high frequencies in the audio source, which can remove some of the noise inherent to low quality samples.
For sound cards, earlier model sound cards tended to have noiser DACs and can be more prone to interference from the computer. Later model AWE32's, AWE64, etc., will sound cleaner in that respect.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 3, by Tempus
I use GUS PnP for sound and SCC-1A (equal to SC-55 Mk. II) for MIDI. GUS PnP has a lot less noise than my SB16 (CT2800).
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
