First post, by zuldan
I recently scored this nice slotket adapter for $20. I was thinking of using it in my ASUS P3B-F v1.3 with a Socket 370 PIII 1Ghz to replace a slot 1 850Mhz.
362.14 KiB
393.73 KiB
Apologies for my noob questions,
1. Do you think the slotket should be compatible with a Pentium III 1000EB processor?
2.What's the best way to cool a socket 370 processor that is attached to a slotket adapter? I'm not exactly sure how a heatsink / fan would attach to the slocket? Do I just use a standard PGA370 heatsink and fan?
Any advice would be greatly apricated.
Reply 1 of 12, by darry
That should work with everything before Tualatin chips (including your CPU).
For cooling, I suggest a low profile copper cooler from, for example, Startech, and an overkill fan, cable tied to the heatsink (or to something nearby).
Reply 2 of 12, by BitWrangler
I think the slotket is good to go, but might need to make sure the motherboard BIOS has latest microcode for PIII EBs
Yes normal 370/Socket A type heatsink that's not fat in the dimension at right angles to the clip will work. However, you probably want to bear weight in mind and use something on the lighter side of adequate. Interference with other things on the board might be possible with tall sinks like some of the orb variety too.
Reply 3 of 12, by zuldan
Thanks for everyone's response. Would this be a good option?
https://www.ebay.com.au/itm/355029558576
Reply 4 of 12, by The Serpent Rider
Too noisy. Look for small Intel OEM box cooler revisions or low-profile copper coolers.
Reply 6 of 12, by The Serpent Rider
May be too wide for slotket - north bridge radiator will be in the way.
Reply 7 of 12, by frankmonk
The best would be an Alpha PEP66(T) if you are lucky enough to find one. This one does also cool the north bridge which does help a lot when running FSB beyond 133. This one was made especially for Slotkets.
Reply 8 of 12, by smtkr
The coolers you've posted will work just fine. But I highly recommend the Startech copper cooler.
I've never seen that slotket you're using, so I can't comment on that. The silkscreens indicate coppermine compatibility, but usually coppermine slotkets have a voltage clamp IC on them.
Reply 9 of 12, by zuldan
frankmonk wrote on 2023-12-03, 14:26:
I have a Google search saved for that one. Thanks
Reply 10 of 12, by zuldan
smtkr wrote on 2023-12-03, 19:15:
I think you are referring to this one. Only problem is its 3x the price of the CPU 🙁
https://www.amazon.com.au/gp/product/B00006B8 … X2GIMA114Z&th=1
Reply 11 of 12, by PARKE
My 1Ghz cpu on slotket runs fine with a stock Intel heatsink.
384.68 KiB
There is also a photo of such a combination in this article about the same " Eagle 30-900SP-000-43c" slotket that you have.
http://www.dansdata.com/slotkets.htm
Reply 12 of 12, by The Serpent Rider
If it fits, that box cooler would be more than enough for 1Ghz Coppermine. Intel fans are also quiet and more reliable.
