First post, by paradigital
So, during the initial in-period reviews of this card, it was touted that the card was an overclocking behemoth, and that the limiting factor was the 300W envelope that couldn't be broken by the OEM (ATI) to maintain compliance with PCIe specs. The card was capable of dissipating 400W in it's vapour-chamber cooling system, and originally the card would have had the "ATI Overvolt Tool" available. It was supposedly pulled relatively early on due to people frying cards with inadequate cooling, but I really want to try the tool for myself, however the handful of links I can find are dead.
A few people recommended the AMD GPU OVERCLOCK TOOL as a replacement, but this doesn't seem to support changing the memory voltage of the 5970.
Has anyone got a copy of this elusive software? Wayback archive doesn't 🙁
The attachment overvolt.png is no longer available
Reply 1 of 8, by supercordo
You can thank me later. I found it the other day after about 5 hours of searching for it. Dont melt your power supply. I think i requires windows vista or 7.
Reply 2 of 8, by paradigital
supercordo wrote on 2023-12-09, 03:16:
What a hero! Many thanks!
And yes, I’m trying 7 😉
Reply 3 of 8, by DrAnthony
Phew, 400 watts on a 40 nm node, that's a spicy meatball!
Reply 4 of 8, by paradigital
DrAnthony wrote on 2023-12-09, 16:03:
800w, I’m running two in CrossfireX 😁
Reply 5 of 8, by The Serpent Rider
400 is 400 watts. Regardless of lithography. That's not something you want to do with stock air cooler though. Especially with two cards, sitting in close proximity with each other.
Reply 6 of 8, by paradigital
The Serpent Rider wrote on 2023-12-09, 19:17:
It’s fine. With the fans manually set to 100%, with additional 120mm both at the rear and front of the cards, in an open test bench, and only running for 5-10 minutes at a time, they never get that hot looking at GPUz logging.
Due to the motherboard I’m using they are also a slot apart, so both cards have adequate intake spacing.
Reply 7 of 8, by DrAnthony
Well as a sheer unit of power of course it's going to be the same. My point is that on a less dense process you've got less transistors switching so that's more power per transistor (which isn't quite power density as a newer node will pack more power per unit area). It's the same reason why don't see a 100 watt draw from a cranked up 386 and why those Fermi GeForce cards were viewed as absolute flamethrowers at the time even if they seem fairly typical for a current card. 400 watts was HUGE for the time.
Reply 8 of 8, by supercordo
Anything good come from this? I didnt see you post any benchmarks.
