First post, by Pelos Tiesos
Hi !!
I've been working perfect with DOS Box for a few weeks, but somes days ago I've bough a Notebook with Pentium M Sonoma 1,6 GHz Processor.
The problem is that I can run the DOS Box Emmulator and works perfect, but when I want to close it, the first executable Window close and the main DOS Box Window remains opened and not responding. Why?
Never before I've been this problem with my desktop computer.
Thanks everyone for your help.
P.D.: Here you can see the Specifications for my Notebook...
www.airis-computer.com/configurador/pro ... #830M16-07
If you want to see these specifications in english look for DCL51 model at...
http://www.compal.com/index_En.htm
Reply 2 of 9, by Pelos Tiesos
I'm working with 0.63 Version. This problem don't happend with older version (with 0.58 to 0.62 versions DOS Box close perfect all windows).
Thanks.
Reply 3 of 9, by Pelos Tiesos
Excuse-me. The link with the specications for my Notebook does'nt works. Here you are a pdf...
My configuration has 1 Gb RAM and 1,5 Sonoma Pentium M Processor.
    Pragma830.pdf
    55.78 KiB
    143 downloads
    Notebook Specifications Airis Pragma 830
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
try swapping SDL.dLL between version
How do you close dosbox ?
ctrl-f9
typing exit
clicking the X on the right top
Water flows down the stream
Reply 5 of 9, by Pelos Tiesos
Thanks for your answer.
I've tryed to close the DOS Box windows with EXIT command and with CTRL+F9 and hapends the same problem: The second window (the first main DOS Box Windows) remains opened.
I've also tried to change the SDL.dll file for one older (version 0.62 for example), and the problem continues.
Do you need more information to find the problem? Thanks again.
Eloy.
Reply 7 of 9, by eL_PuSHeR
Rank Moderator
Moderator
Try adding a -noconsole parameter to the shortcut that launches DOSbox and see what happens.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
