First post, by benvanderjagt
Hi all! First time poster, long time lurker. \o
I've got a Turtle Beach Maui (rev 1.0, though I don't know if there was ever another revision). I had a TBS-2001 for a long time. It perished, but at least I know a bit about the odd software setup. I'm testing it with a Pentium-II motherboard, as it's the only one I have that is willing to free up enough resources for the card to initialize. After running setupsnd (or initializing it in Windows 3.11 and waiting for it to go through its delayed initialization process), I'm able to start playing a MIDI or start a game, and it acts like it's playing audio. (Other sound cards seem to work alright on the same ISA bus, and the speakers are amplified and work fine.)
I recently bought this card and it played the first time I tested it, so I'm honestly not ready to simply say it's dead. I also crudely probed the DAC's for a signal with the tip of the 3.5mm jack and heard no signal. The diag utility also says the card checks out.
Regardless, I'm stumped! (= I really, really LOVE the Turtle Beach WaveFront, and I would spend some money for a good working card, but they just don't seem to exist anymore. I bought this one to replace my superior one, so I'm a bit disappointed.
Thanks in advance!
Reply 1 of 17, by benvanderjagt
I don't detect a clock going to pin 16 on the DAC (D6376). When it's "playing" audio, it does create clocks to everything else, including the hex switcher. That signal varies depending on the actual MIDI being played, as well as the RAM it's pulling wavetable data from. I checked for continuity from the clock pin on the DAC to pin 60 on WaveFront ICS2115V, and it reads 0 ohm. Now to see if I can find out why the WaveFront ICS2115V isn't generating (or passing?) a clock.
(Edit: I tested wrong. There is a proper clock going to the DAC. So now, I'm back to trying to figure out why it seems to be processing, reading and writing RAM, and the two WaveFront chips are operating, but there's no actual audio going through the DAC. It's as though the chipset is going through the motion of playing MIDI, then throwing it in the trash.)
Reply 2 of 17, by Rawit
Can setwf143 see the card? You can also set the volume with that tool. What MOS file are you loading?
YouTube
Reply 3 of 17, by benvanderjagt
I just grabbed a copy and am trying it now. I've never used this tool before, so I'm going to spend some time researching and playing with it. Thank you! I've been loading OSMAUI.MOT. I was tempted to try the TBS-2001 tools and see if they produce different results.
Reply 4 of 17, by benvanderjagt
"setwf -s" says
WaveFront Hardware Version: 1.64
Firmware Version: 1.14
Synthesizer Volume: 119
Number of Voice: 32
Synthesizer Tuning: 0
Virtual MIDI Mode: Disabled
Virtual MIDI Switch: Synth
MIDI-In to synth Mode: Enabled
Number of samples: 40
WaveFront Sample DRAM size: 262144 bytes.
WaveFront Sample ROM size: 1048576 bytes.
WaveFront Free Memory: 262144 byte(s)
I'm testing right now with the RAM removed, but it does report the additional RAM when I insert it. I'm curious whether the card is sending all MIDI out through the DB9 plug. (I'm also curious whether soldering in a WaveBlaster connector would allow it to run with a SB16.)
Reply 5 of 17, by Rawit
The output shows that volume has a correct value. Setting an illegal value can happen but isn't the case. I'm confused however by "Number of samples". I can't recall what I had with the Tropez/Maui but it seems an odd number. WaveFront does 512 samples max. and uses ~350 samples in ROM if I'm not mistaken. WaveFront Sample ROM size: 1048576 is odd as well. It states ~1 MB, you should have 2 MB of ROM.
I would remove all memory and inspect the solder joints around the ROM chips and run setwf again. Perhaps it's playing but missing instruments.
YouTube
Reply 6 of 17, by benvanderjagt
That would fit with its behavior, particularly if the ROM is only giving out zero's. Bank switching is happening during playback, too. Either a RAM chip flattening out all of the data or the ROM failing to push out any samples could do it.
I'll try that next.
Reply 7 of 17, by benvanderjagt
I haven't sourced any 514256 chips I can use, but they are Toshiba chips (which are dubious for the period). *shrugs* I ordered some OKI chips, same speed. I did find some near shorts on the caps near the RAM, so chances are one of them is shorted out. (I did pull the caps and test them, just to be safe.)
I wish I had this level of understanding when my Tropez Plus died. That was my dream card...and I have not seen another for sale for any price.
Reply 8 of 17, by Rawit
What was the issue with the Tropez Plus? Those are rare but one of the greatest cards, at least on paper.
YouTube
Reply 9 of 17, by benvanderjagt
It simply stopped responding. I did a quick check for broken solder joints or shorts, but I didn't know enough to dive any deeper. I sold it on eBay for parts/repair, and even in non-working condition it sold for more than enough to buy this Maui. I know that wavetable sound is a very personal, subjective measurement, but I've played music samples for quite a few games and MIDI files for friends who were not around for the great wavetable battle of 1994, and they all agree that the Turtle Beach's samples and processing are hands-down the best. It was a real PITA to get working, but that's another story. 😁
I was hoping there would be a way to load at least the samples from the TBS-2001 into the Maui, but I had not gotten that far before this card stopped working.
Reply 10 of 17, by Law212
Have you plugged in some speakers?
Reply 11 of 17, by benvanderjagt
Yes I did, and I also probed the DAC to see if it was receiving or sending any signal. It has power and clock, but it's receiving zero's and sending silence.
Reply 12 of 17, by benvanderjagt
Phooey. So far, I've confirmed that none of the data or address lines on the two TC514256AJ-70 DRAM chips next to the RAM slots had any activity. I replaced them with Siemens HYB514256BJ-70 chips. It identifies the 256K of RAM. (If I disable the chips, I can put 2M in the slots and it recognized just the 2M.) It now shows 3 loaded samples. Running MAUIDIAG used to pass, but now it results in ROM checksum errors. I reflowed the pins to the ROM and have the same result. Now, it *could* be that it doesn't like the Siemens chips. I haven't tried the OKI chips yet, and I *could* order the original PN Toshiba chips. It's also possible that there is a short elsewhere that's keeping the RAM at zero.
Edit: I'm stupid. I didn't flow the SampleROM. I flowed the boot ROM. I re-flowed the SampleROM and now it has 332 samples loaded.....but now it's zero bytes of DRAM! D= Gah, I can't win! Funny enough, DIAGMAUI doesn't bat an eye at having zero RAM.
Reply 13 of 17, by benvanderjagt
I GOT THE *!@#%$!@$# WORKING!
This card must have had a fall or something. The RAM chip closest to the slot *still* doesn't have any data out. After reflowing the ROM, I got 332 samples loaded. Then, I added a matching 256K SIMM in the first slot, and it seems to be piggybacking the onboard RAM chips. (Removing the RAM chips and putting RAM in slot zero does not work. The card won't start.)
So, from what I can tell at this point, it's doing R/W to chip 0 onboard simultaneous with chip 0 on SIMM 0 while disabling chip 1 onboard and relying on chip 1 on the SIMM. 1M stick in slot 0 does not work.
I'm not sure if I want to try replacing the onboard RAM yet again or just being satisfied with a functional card.....
Edit: The OKI chips identify (incorrectly) as 1M chips. That makes me wonder if the board *would* support 1M chips onboard. I'm just too fatigued from one after another chip swap to risk any more changes. I'm ordering two NOS Toshiba chips of the exact same P/N.
Edit 2: I pulled the OKI chips back off, and pin 5 appears to be NC. 1M onboard chips won't work anyway. It seems like it should be possible to bodge that pin in (and theoretically go above the 8.25M maximum).
Reply 14 of 17, by Rawit
Glad to read you got it working. So, if I'm not mistaken, the on-board memory died and caused all these issues?
YouTube
Reply 15 of 17, by benvanderjagt
It was more the solder joints on the WaveROM, but the onboard RAM was shorted too. I feel like something must have happened to the card, like an impact or a surge.
I didn't mention the incident of failure. It was working fine until I decided to install Windows 95. It had 3.11 and was working fine, and it went bad sometime while installing 95. Turns out that was irrelevant, but the strange thing is that it the card didn't go anywhere between working and not working.
Reply 16 of 17, by benvanderjagt
*sigh* Well...it's dead again. The WaveROM isn't recognized. I removed and resoldered it and checked all of the solder joints. At this point, I'm shelving it and searching (in vain) for another card.
Reply 17 of 17, by benvanderjagt
On a hunch, I reflowed all of the joints on the two adjacent chips (the WaveFront IC and the Motorola CPU), and it's been working since then. Maybe the solder joints on the entire board are cracking. In any case, I'll keep my ears out for another TBS-2001, even in non-functional condition.
