First post, by ReignerDeustcher
With dgvodoo2 the game runs fine but all the texts are in black... i've read in pcgaming wiki that you have to switch to opengl but there's no option like that in dgvodoo
how can i fix it in d3d?
Reply 1 of 3, by eddman
dgvoodoo is a Direct3D wrapper, not OpenGL. You have to select OpenGL in the game's settings, and remove dgvoodoo. EDIT: it's a mod, so you'd have to get it separately.
Saying that, IINM the game worked fine with dgvoodoo the last time I checked. Try older dgvoodoo versions to see which one broke it.
Reply 2 of 3, by ReignerDeustcher
eddman wrote on 2023-12-13, 11:29:
dgvoodoo is a Direct3D wrapper, not OpenGL. You have to select OpenGL in the game's settings.
do you remember what version was the working one? just tried some of the old versions and it's the same
Reply 3 of 3, by Dege
Either it's not broken or the black text phenomenom must appear under certain circumstances/configurations. No problem here with the latest version.
