First post, by Cosmic
This is a silly post, but I was curious if anyone else feels the same way.
I picked up a clean 486 PC from an estate sale this past summer, it even came with the keylock key. It seemed like a system someone bought new and upgraded a few times over the years but otherwise was stock. I swapped the ES1869 AudioDrive for an Intel EtherExpress 8/16 to do some setup and testing over the network, but having no sound is a bummer. I want to put my SB16 CT2290 (1993) in this rig but also keep the network card, which means I'd have to pop out one of the stock slot covers.
This is silly, but I almost feel bad popping out a slot on this otherwise super clean AT case. 😂 It'll never be able to go back to it's original config, you know? At least one of the slot covers under the VGA card is already kind of loose, so I'd probably put the network card there, and the SoundBlaster at the bottom.
Anyway, just wanted to share this nice AT case and see if anyone else hesitated to make a one-way change to an old case like this. Case badge is from Geekenspiel. Cheers.
Original specs:
  • Mobo: DTK PKM-0037S, SiS 85C461, PGA 168 (BIOS 1993, chip 1994)
  • CPU: 486 DX-50 (SX710) (1991)
  • RAM: 8MB 30-pin FPM (1994)
  • IO Card: Relialogic CA9342 ISA (1993/1994)
  • Disk: Quantum Bigfoot 1.2GB (1996)
  • CD-ROM: Teac CD-W58E (2000) (Maybe was replaced later)
  • Sound: ES1869 AudioDrive ISA (1996)
  • Video: Cirrus Logic CL-GD5426 VLB (1993)
p.s. happy DOOM day!
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
Reply 1 of 12, by Horun
Nice ! I never have a problem popping out the back slot covers, have dozens of replacements I can screw in.
Reply 2 of 12, by Grem Five
I seem to be the opposite. Every time I get a new case 1st thing I have to do is break all the slots covers loose then put them back in.
Now I have the problem you describe with case knockouts but not slot covers. Probably because slot covers can be screwed back in but not knockouts.
Reply 3 of 12, by Cosmic
Grem Five wrote on 2023-12-11, 02:07:
Yeah, that's my only hesitation, haha. On one hand this machine never had a network card, so part of me wants to keep it intact/stock. On the other hand, having network + sound is really handy, so I want to remove the knockout.
But it is DOOM day and I want to play, and I use the network card for an XT-IDE ROM, so I might just have to do it. 😁
Reply 4 of 12, by Cosmic
Good news and bad news. I removed the knockout slot cover and installed the Intel EtherExpress 8/16 + SB 2290. It booted but I forgot to plug in my CF card so I powered off, installed the card, and booted again. Afterwards - nothing. No output...
I restored the original config, nothing. Took the NIC and SB out, nothing. Took the IO card out, nothing. Took the VLB VGA card out, nothing. The POST card shows activity on the bus when powered on, it settles at codes 0x13 + 0x12, then 0x00 and 0x13, then does nothing. So... have some troubleshooting to do. I don't have any other VLB or ISA video cards to test with currently.
This resource for the AMI BIOS says 0x13 is "System-interrupt vectors initialized" and 0x00 is "Call the Int19 boot loader". The time between the codes seems to be about the same time as this system takes to check the 32MB of RAM installed. Almost like it's booting but there's no VGA output. Plugged in the PC speaker but no beeps.
Maybe putting the card in a brand new ISA slot, never used for 30 years, somehow broke something? I'll have to check the tantalum caps for shorts, but I assume it wouldn't get this far if the ISA bus was shorted.
Cards installed:
vb3TtPi.jpg\
Failed POST:
Reply 5 of 12, by Trashbytes
Ouch, sadly this is pretty common with old hardware, the force required to insert the ISA cards can crack solder joints and such, you may want to check continuity across the ISA slots. Since they are all wired up in parallel this shouldn't be a hard thing to check, you might also check to see if all the pins on the ram slots have continuity also.
Stuff like this is like looking for a needle in a ISA slot.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 6 of 12, by wbahnassi
You can sometimes preserve the slot covers by just pushing them away without breaking off from the case (that is, don't keep wiggling them till they break loose). When you remove the card that used that slot, you can bring the cover back into its original rotation.. it could probably take it once or twice before coming loose eventually.
And good luck with the board repair.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 7 of 12, by b0by007
Becouse of the usually spaghetti ide calbles mess and the passive cooling of the 486 and even pentiums, I allways remove the slot covers and replace them with these:
The attachment slot covers.jpg is no longer available
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 9 of 12, by Shadzilla
vetz wrote on 2023-12-11, 10:44:
Since the case is "pristine" I'd use gloves when working on it to avoid fingermarks oxidizing in the metal over time.
I think you're joking..... but the thought has crossed my mind, when working on my Lian Li cases after I've cleaned all the untreated aluminium on the inside and they look brand new again. Maybe I should ask for a nice set of white cotton gloves for Christmas 😅
OP - totally with you on the dilemma for preserving originality. I think expansion slot covers are a necessary evil though. I'd probably take them all out and then fit a matching set of covers. Nothing worse than a mis-matched set of expansion slot covers...
Reply 10 of 12, by DerBaum
i would have taken out the top slot cover with the gameport and the large serial port.
Today i normally use just one serial for a mouse so i dont need a second one for a modem or else... and the sound card has a gameport.
FCKGW-RHQQ2
Reply 11 of 12, by Cosmic
Trashbytes wrote on 2023-12-11, 07:21:
Thanks, it really does feel that way haha. But it's worth a shot. Thanks for the advice.
wbahnassi wrote on 2023-12-11, 10:24:
That's a really good idea. I broke this one out before I read your comment, but I could see it working - it really did take some flexing to remove it.
b0by007 wrote on 2023-12-11, 10:40:
The way to go, really. And all-new slot covers always look nice. I have some really shiny matching ones in another rig 😁
Shadzilla wrote on 2023-12-11, 11:39:
Agree. If I can get it working again, at least it will have a very nice stock look!
I'll keep track of any updates in a better named thread. Hope to post back here soon with a working rig...
Reply 12 of 12, by H3nrik V!
Since a previous owner already did upgrades over the years, in my opinion, it isn't 100% original anyways, so I'd just break away - and maybe get matching covers to fill up ...
