First post, by Perfect
Hey everyone.
I've got my first SS7 board today and can't for the life of me figure out how to get the FSB at 83MHz. I'm using a K6-2 500MHz in it and have managed to get it to 400MHz (6x66) but no higher.
https://theretroweb.com/motherboards/s/achite … perwav-achi-156
I believe the first 2 dip switches control the multiplier but no clue what the other ones do.
Reply 1 of 4, by Gmlb256
Hello and welcome!
From what I understand about the MTL jumper manual, S1 does set the CPU multiplier and FSB speed.
For the CPU multiplier, from S1/1 to S1/3 is used to configure the CPU multiplier:
      S1/1 S1/2 S1/3
2.0x: On Off Off
2.5x: On On Off
3.0x: Off On Off
3.5x: Off Off Off
4.0x: On On On
5.0x: Off On On
There are two remaining combinations for 4.5x and 5.5x multipliers, the former one displayed on the manual is the same as 4.0x which is incorrect.
S1/4 to S1/6 are the ones that sets the FSB speed:
        S1/4 S1/5 S1/6
60 MHz: Off On On
66 MHz: On Off On
75 MHz: Off On Off
More FSB speeds can be achieved with five remaining combinations, but I don't know exactly which PLL clock generator uses, so I can't help further.
Reply 2 of 4, by zyga64
According to jumper manual on TheRetroWeb (for FSB 75MHz, and multiplier 2x) dip switches should be set as following:
S1/1 - on,
S1/2 - off,
S1/3 - off,
S1/4 - off,
S1/5 - on,
S1/5 - off
Edit:
@Gmlb256 sorry, you already wrote it... 😀
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 3 of 4, by rmay635703
You could just set your multiplier to 2.5x and try setting the jumpers to every available combination (there are only 8 combinations)
Record the result. You might have some very high or very low FSBs that don’t work.
You could also take a clear closeup of the clockgen / PLL area and post it.
If I had to venture a guess On On On is probably 50mhz, off off off is probably a high frequency.
Reply 4 of 4, by Perfect
Thanks for the help guys I ended up getting it to work. I probably figured this out ages ago but I didn't realize the BIOS doesn't show higher than 400MHz (even though it is).
For anyone that finds this in the future it ended up being;
S/1 On
S/2 Off
S/3 Off
S/4 On
S/5 Off
S/6 Off
