First post, by Muz
I am trying to run Tie Fighter in emulated programs such as DREAMM and PCem, I find it my USB Logitech joystick always veers to the right in cockpit, why is this happening in the emulator?
Reply 1 of 2, by Rwolf
Isn't this one of the old games that you need to calibrate the stick in *every time* you start it up? (I haven't run it for awhile, so I forgot)
In DOSBox, you could set the joystick polling to 'timed=false', not sure what your pc emulation requires.
Reply 2 of 2, by AirIntake
Rwolf wrote on 2023-12-12, 17:23:
Yes it is. If you don't calibrate the joystick correctly you sometimes can't even navigate the menus since the joystick also moves the mouse cursor.
Casio BE-300 Advancement Society (be300.org) alumni
