First post, by rakun86
I have problems with recently acquired Matrox G400 card.
When i plug the card without the drivers, it works fine (low res, few colors). After installing the driver i have vertical lines on the screen. Start up, BIOS screen, Windows splash screen and Safe mode are great with no lines, but as soon as the desktop shows, a lot of vertical lines of different colors appear in both VGA outs.
I had similar problem with G450 a year ago. I should note that both cards were bought as is, not tested, but its highly unlikely that both have the same problem? Other GPUs that I have work with no issues in that AGP slot. I did the Matrox Bios flash on the card, tried several versions of drivers... no luck so far.
Anyone have any ideas?
The MOBO is Chainthech 440BX with PIII 550.
Reply 1 of 7, by PD2JK
Sounds (looks) like a video memory issue.
Best way to rule things out is trying the card in another system.
Any physical damage on the card, like missing capacitors or touching/shorting video memory solder leads?
Have you tried lowering the refresh rate? Could be the RAMDAC.
Pics! :p
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 7, by Thermalwrong
Run Video memory test from a floppy disk (VMTCE), that sounds just like what I was fixing on my Voodoo 3 & Banshee cards the other day. The banshee had the same behaviour where it looked fine in 16 colour mode but 256, 16-bit and 32-bit colour modes were very broken.
Reply 3 of 7, by rakun86
Thats the only AGP mobo that ive got. No damage. Ive lowered the refresh rates and nothing changed.
Here are some pics... 16 and 32 bit are bad, the lowest number of lines are in 24bit
VMTCE showed a bunch of errors... got bored and stopped it but i was a lot. So the problem is the memory on the card?
Reply 4 of 7, by Thermalwrong
Yeah it's the RAM, my Voodoo Banshee behaved exactly the same with some damaged / non-functioning memory lines - interesting that you also see the least corruption at 24-bit, mine was the same in that aspect as well.
See if the display clears up when you squeeze the BGA chip to determine whether it's a memory pin fault or a BGA fault. One of my cards did clear up when squeezed in one corner and that means the BGA balls under the chip have come loose and the chip either needs a reflow or a reball, which is not something to do carelessly. If that doesn't make a difference then it's probably a loose leg on one of the QFP memory chips - your card uses rectangular SGRAM right?
Could you attach the VMTCE log file, I don't know how your card lays memory out but you're seeing the same glitch I was and the Banshee is pretty similar in RAM / capability to the G400.
Reply 5 of 7, by rakun86
It showed allot of errors... Ive stopped it after a few minutes.
No difference when squeezing.
I think its SGRAM. Ive uploaded a pic of the card like mine. Either way, if its not software related... its no use for me. I cant really solder anything that is that small and fine.
Reply 6 of 7, by Thermalwrong
rakun86 wrote on 2023-12-13, 20:45:
Probably best to get a new card and recycle / sell off the broken cards then, it takes a fair bit of soldering experience, good quality flux and probably a micrcope to fix issues with QFP SGRAM memory chips like that. I consider myself to be experienced but I still make a mess of soldering such fine pitch chip legs.
Reply 7 of 7, by rakun86
In the bin with the faulty G450 it is then... and my trusty ati 128 pro back in the AGP.
Thanks for the help.
