First post, by Griff3125
Off the wall question, I just noticed that if I do 'properties' on my computer, it's showing 511MB's of memory.
I have 512 total, my bios shows 512 (256x2), is this just a quarky limitation that I've never noticed before?
Everything's working fine, no errors anywhere, I'm just curious if this is normal?
If it helps, Windows98 SE with unofficial pack 3, PIII 1ghz, 440BX mainboard, voodoo 5500.
Appreciate any insight to this.
Reply 1 of 7, by DeathRabbit679
Isn't it less the UMA and conventional area?
Edit: To clarify, I'm kinda asking too, I always assumed because both my win98 machines show up with 1 meg less, so I figured it was the no touchy with the first meg
Reply 2 of 7, by Standard Def Steve
My 98 box reads 511MB as well. Since Win98 sometimes behaves erratically with 512 or more, and also since this same installation of Win98 reported the full 256MB back when I only had that amount of memory, I like to think of the 511 thing simply as Win98 trying to save itself. I...know that's not what's actually happening, but it almost sort of anthropomorphizes that dumpster fire of an OS, in a way.
"A little sign-in here, a touch of WiFi there..."
Reply 3 of 7, by Trashbytes
512Mb is the technical limit of what Win98Se can address without having a meltdown or requiring patches, its likely not reading the amount correctly due to that limitation. Sounds like the same thing XP 32bit does when it has 4Gb of ram, itll only ever display 3.5 of it due to 32bit limitations.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 4 of 7, by Griff3125
Thanks for the replies, I've been finding the same results elsewhere, so I guess it's pretty much the norm.
Cheers!
Reply 5 of 7, by BolenB
Griff3125 wrote on 2023-12-14, 03:28:
If Emm386.exe is loaded into Config.sys, then this is what happens...
Reply 6 of 7, by progman.exe
Is there a BIOS option called something like 1M memory hole? Or is my memory full of holes? IIRC there was some feature in BIOSes for compatibility, perhaps, that, for some reason, maybe, turned off 1 meg of RAM, or not. Not sure I trust myself, if you can't tell 😀
Reply 7 of 7, by midicollector
Possible that one mb is being used for some kind of error correction/detection/parity.
