First post, by egbertjan
I have two retro PC's with a Asus P5A-B rev 1.04 mainboard. I have DOS 6.22 installed. When I format a floppy disk I hear a terrible uninterrupted beep coming out of the PC-speaker. In both PC's I have a soundcard, one with a Mozart OTI601 rev B and the other with a Creative AWE 64 Gold. The same beep comes with the Sound FX of Duke Nukem 3d on the Mozart card. I can end the beep only by power off or resetting the computer with the reset button. In my other retro PC's I don't have this problem. Is there anybody who knows this problem and can help me solving it.
Reply 2 of 16, by PD2JK
This introduces a new dimension of the hanging note bug.
First thing which comes to mind is indeed some boot sector virus protection, but this should come from the PC speaker (if not routed through a sound card).
It could also be some resource conflict, but i'm guessing you're not using IRQ #6 for sound.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 3 of 16, by egbertjan
PD2JK wrote on 2023-12-15, 12:35:
The beep is indeed coming from the PC speaker, not from the Mozart. As far as I can see is an IRQ-conflict out of the question.
Reply 4 of 16, by Grzyb
What exactly are you doing? The "format a:" command?
What happens when formatting using other tools, eg. under Windows?
No problems with reading and writing, only with formatting, right?
Have you tried with minimum software config, ie. empty CONFIG.SYS and AUTOEXEC.BAT ?
Have you tried with minimum hardware config, ie. no cards other than graphics?
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 5 of 16, by Horun
Easiest way to narrow down hardware issues is: remove everything not essential. If the motherboard with nothing but video card booting DOS on an HD and then you try to format a floppy gives an error you then there is a big issue.
Have you tested the floppy drives in other computers ? Are you using a beta or patched bios ? What video card ?
Reply 7 of 16, by egbertjan
I installed on the PC nothing but DOS 6.22 and removed all the cards except the NVidia videocard (PCI slot). Further on I had a PS2 mouse installed. Starting format A: caused once again the beep as mentioned in the posts above. With an S3 video card instead of the NVidia the result was the same. I want to try if the beep is coming under windows 3.11.
Reply 8 of 16, by Deunan
egbertjan wrote on 2023-12-16, 11:06:
The beep is not coming when I do format a: under Windows 98 SE. I will do some of the other tests.
Win95 and later systems do not use BIOS to access floppy drives in favour of 32-bit protected mode code, and that would explain why there are no beeps. The boot sector protection code is not being triggered.
Did you try DISKCOPY in pure DOS? AFAIK it will overwrite the bootsector so that should trigger the BIOS during write as well.
Reply 9 of 16, by Grzyb
There's also software for DOS that accesses the FDC directly - try eg. Diskdupe.
Reply 10 of 16, by elszgensa
Deunan wrote on 2023-12-19, 14:35:
Yeah... I noticed that so far OP has not said a peep about having looked into this. Whenever I volunteer to help people and they flat out ignore my suggestions, I've found it's overall best for my mental health to just abandon thread. Maybe they come around later, maybe not, no skin off my back. But if you have the time and nerves to keep prodding, more power to you.
Reply 11 of 16, by egbertjan
I have loaded the default settings in the BIOS and compared all the settings with the ones I entered before. I found out that the Delayed Transaction must be disabled. When it is enabled I get the beep after format A:. It also turned out that the problem with the Mozart soundcard was over. Does anybody know what the function of the Delayed Transaction is?
Reply 12 of 16, by weedeewee
egbertjan wrote on 2023-12-19, 20:08:
is it this https://www.techarp.com/bios-guide/delayed-transaction/ ?
Do not ask Why !
Reply 13 of 16, by Deunan
That is very odd. I wonder if there might be a bug in the BIOS code, and the floppy routine is somehow tripping it unless the mobo/chipset is set to specific values that don't trigger the bug?
The Mozart card might indeed have some issues with Delayed Transaction but the FDC is part of the mobo. If you have free ISA slots you could try disabling the onboard FDC (and perhaps IDE as well) and adding extra ISA-based card to handle floppies and HDD. Just for testing, to see if that too triggers the beep.
BTW posting some photos of your BIOS settings could be useful at this point, maybe someone can spot a setting that can be tweaked.
Reply 14 of 16, by egbertjan
Here I post the photos Deunan asked for.
1.65 MiB
1.79 MiB
1.15 MiB
1.62 MiB
1.27 MiB
Besides, is there someone who can give suggestions for better settings?
Reply 16 of 16, by Grzyb
maxtherabbit wrote on 2023-12-27, 00:06:
"Floppy disk access control" is a curious option. What are the choices under that?
R/W
Read Only
