First post, by sdz
I got this trashed V5 5500 PCI a few years ago, and for another project I needed a V5 with DVI to test some things (my other one literally caught fire.., a repair for another time), so it required some repairs.
It looked something like this:
The attachment 20190629_191407.jpg is no longer available
The attachment 20190629_191453.jpg is no longer available
The attachment 20190604_012914.jpg is no longer available
The attachment 20190604_012842.jpg is no longer available
The attachment 20190604_012837.jpg is no longer available
Reply 1 of 8, by sdz
I first repaired the minimum stuff required for testing: fixed broken traces,replaced the broken/missing resistors. Did not replace any caps, just removed the ones that were cracked and could cause a short. Also added the missing 14.318MHz crystal.
After that I was able to get the master VSA working, so I went on.
Second VSA sort of worked after reflowing it, but in the end I had to replace it. Most likely some of the traces in the substrate were damaged, as some excessive force was applied to it at some point (could see fracture lines under the microscope). When desoldering it, 4 pads also lifted from the PCB. These pads were located in corners, and probably already lifted separated from the PCB while the heatsink was forcefully removed at some point.
Anyway, after replacing all the missing SMDs, fixing traces and pads, new inductors, new crystals, new electrolytic caps, new VSA and some upgrades (128MB RAM, DVI output), here it is:
The attachment 20231215_211736.jpg is no longer available
The attachment 20231215_212321.jpg is no longer available
The attachment U1.jpg is no longer available
(sorry for the shadows, I'll upload some better pictures later).
Reply 2 of 8, by sdz
Ran some 3dmark 2001 SE benchmarks, test system is a 3770K@4.6, 16GB DDR3@2000, Windows XP SP3 with SFFT 1.9 drivers.
Stock card in 33MHz PCI bus: 2904
128MB RAM, core&memory clocked at 184MHz, PCI bus clocked at 95MHz: 3777
The attachment 20231215_212620.jpg is no longer available
The attachment 20231215_213503.jpg is no longer available
I can't push it past 184MHz at the moment, I'll upgrade the cooling (probably design a custom cooling solution for the whole card) and then I'll see if I can get it higher, maybe increase the VSA and RAM voltage a bit.
I should also have some Rev 320 VSAs somewhere, but that will be a last resort, as this PCB has already been through enough.
Reply 3 of 8, by sdz
If anyone is curious what the hotspots are:
The attachment IMG_20231216_115156.jpg is no longer available
The attachment IMG_20231216_115301.jpg is no longer available
The attachment IMG_20231216_115306.jpg is no longer available
The attachment IMG_20231216_115552.jpg is no longer available
The attachment IMG_20231216_115604.jpg is no longer available
Reply 4 of 8, by analog_programmer
Very good job! How did you manage to find out what elements are needed for the unpopulated pads for the DVI-output? What camera/postprocessing did you use for these "thermal' images?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 5 of 8, by sdz
Thanks!
I measured the components on the other dead V5 DVI that I had.
Those are actual thermal images.
Reply 6 of 8, by analog_programmer
sdz wrote on 2023-12-17, 14:53:
Thanks!
You mean that you've unsoldered these SMD components from the other repaired Voodoo5 card one by one to measure their values and then soldered them back to their places?
What thermal camera you're using?
Reply 7 of 8, by sdz
Yes, I measured everything.
I'm also working on this:
Voodoo2 component map + schematics
But for the Voodoo 5 5500 PCI VGA and VGA&DVI versions. Should be ready in a week or so.
The camera is a MobIR 2T. 256x192 pixels, with autofocus.
Reply 8 of 8, by analog_programmer
sdz, thank you for the info and the link. These component maps are very useful for repairs.
